- Acer ED273 - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/397325
- Energy Class
- Class F
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 26 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- White
- 61.28 cm x 16.82 cm x 46.59 cm
- Localisation
- United Kingdom
- MPR II, DDC-2B, FCC Part 15, DDC, WEEE, EN 50564:2011, EN 50581:2012, Directive 1275/2008/EC, RoHS 2011/65/EU, EN 61000-3-3:2013, EN 55024:2010, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, EN 61000-3-2:2006+A2:2009 Class D, EN 55022:2010+AC:2011 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 44 kWh
- Diagonal Size
- 27"
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 5500K
- HDCP, Overdrive technology, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), game mode, ComfyView, Flicker-Less technology, Transition Minimised Differential Signaling (TMDS) technology, Blue Light Filter technology, 6-bit gamma, Wide Viewing Angle, Colour Temperature Selection, Movie Mode, Acer BluelightShield technology
- White
- 61.28 cm x 16.82 cm x 46.59 cm - with stand
- DisplayPort , DVI (HDCP) , HDMI , Audio line-out (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- LED indicator
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort
- Localisation
- United Kingdom
- Input Voltage
- AC 120/230 V
- 26 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 61.28 cm - depth: 16.82 cm - height: 46.59 cm , Without stand - width: 61.28 cm - depth: 7.54 cm - height: 36.19 cm
- Limited warranty - 2 years
