BlueLightShield technology reduces the exposure of blue light, which can be potentially harmful, by adjusting color hue and brightness. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand. Flickerless technology eliminates screen flickering by providing a stable supply of power to the display. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
Features& Specs
FHD (1920 x 1080) Resolution- Clearer, Sharper Images ZeroFrame, Ultrathin Display- Improved Enjoyment and Maximum Visibility Gently Curved 1800R Screen- A More Immersive Viewing Experience 4ms Response Time- React and Respond Quickly to What You See on Screen BlueLightShield Technology- Reduces Exposure to Blue Light Flickerless Technology- Eliminates Screen Flicker ComfyView– Reduces Reflections from Ambient Light Sources
- Acer ED242QRwi - LED monitor - curved - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/397323
- Energy Class
- Class F
- Energy Consumption per Year
- 40 kWh
- Power Consumption (On mode)
- 27 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.27156 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 84%
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- White
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 40 kWh
- Diagonal Size
- 23.6"
- Curved Screen
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27156 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 84%
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ComfyView, Flicker-Less technology, Wide Viewing Angle, Acer BluelightShield technology, Ultra-Low Blue Light Technology
- White
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x VGA cable
- 27 W
- Power Consumption SDR (On mode)
- 23 kWh/1000h
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Limited warranty - 2 years
