A perfect blend of style and form, the EB2 series monitor combines a brushed, textured finish with useful ergonomic features. Crisp, true-to-life colors come alive in Full HD 1080p resolution with the EB2 series monitor.
Time to mount up
Choose where to place your monitor for the best viewing experience possible with VESA wall mounting. -
Find your angle
Able to shift from -5° to 15°, the stand tilts to ensure a viewing angle, that is comfortable and effective. -
Feel the difference
The brushed and textured surface of the EB2 series monitor presents itself to you with a unique sense of style. -
Full HD quality
The EB2 series lets you view movies, do work or relax with a game in 1920 x 1080 but with sharp clarity. -
The power of a panel
The EB2 series monitor features a panel, allowing colors to be presented accurately with a viewing angle of up to 178°. -
View in comfort
Acer ComfyView technology reduces the amount of light being reflected on your display for more comfortable viewing in various settings. -
100 million:1 contrast
Acer Adaptive Contrast Management (ACM) delivers optimum brightness and contrast to enhance overall color quality.
- Acer EB222Q - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class E
- Power Consumption (On mode)
- 14.6 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 200 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 50.4 cm x 18.9 cm x 38.3 cm
- 2.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Mercury free, 6-bit gamma, 72% NTSC colour gamut
- Black
- 50.4 cm x 18.9 cm x 38.3 cm - without stand
- 2.4 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA interface support
- Cables Included
- 1 x VGA cable - VGA to VGA
- MPR II
- Input Voltage
- AC 120/230 V
- 14.6 W
- Power Consumption SDR (On mode)
- 14.6 kWh/1000h
- Power Consumption (Typical)
- 23.5 Watt
- Power Consumption Stand by
- 450 mW
- 400 mW
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
