Acer EB321QUR 31.5" 2560x1440 1ms DVI-DL HDMI DP LED Monitor
Quicklinx: DB0CWS00 Mfr#: UM.JE1EE.009
Acer EB321QUR - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class A
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
MPR II
Display Type
Energy Class
Class A
45 kWh
Diagonal Size
31.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
10-bit gamma, Flicker-Less technology, Blue Light Filter technology
White
HDMI , DVI (dual link) , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+20
1 x DisplayPort cable , 1 x DVI cable
MPR II
Input Voltage
31 W
Power Consumption (Typical)
75 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
