Acer EB321HQUwidp 31.5" 2560x1440 4ms DVI HDMI DP Monitor
Quicklinx: CP95WS00 Mfr#: UM.JE1EE.A01
Acer EB321HQU - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
81 kWh
Power Consumption (On mode)
55 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
White
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
81 kWh
55 W
Diagonal Size
31.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
CrystalBrite, Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), Mercury free, Flicker-Less technology, Blue Light Filter technology, 8-bit gamma
White
VGA , DVI-D (dual link) , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+10
VESA 100 x 100 mm
1 x DVI cable , 1 x DisplayPort cable
MPR II
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
ENERGY STAR Certified
