Create and view designs, videos, and animations in incredible detail with a ConceptD CP5 series monitor. Achieve professional-levels of color fidelity with the PANTONE® Validated display, a 99% Adobe® RGB gamut, and Delta E <1 color accuracy. Combined with Vesa Certified DisplayHDR 600 and an overclockable refresh rate of up to 170Hz for blur-free images, a high quality viewing experience is guaranteed.
Outstanding HDR Experience
Experience realistic, natural images through the expanded contrast ratio and color palette guaranteed by VESA Certified DisplayHDR™ 600. Create images with improved brighness and contrast with darker blacks and whiter whites with greater depth and shadowing.
Wide Color Gamut
Get brighter and more lifelike colors with Adobe RGB 99% color gamut’s extended color range. Adobe RGB is an international color standard used by directors and producers and ConceptD CP5 series monitors are designed to match this professional-grade quality, making them ideal for high-level editing of imagery and photography.
Perfect Colors
An artist should have confidence in their tools. With Delta E <1 color accuracy and a PANTONE® Validated display, ConceptD CP5 monitors are backed up by color technologies that ensure vivid, true-to-life color reproduction.
Delta E <1
The display has been tested and calibrated to achieve a low Delta E average of <1 to reproduce true-to-life color accuracy.
PANTONE® Validated
Get a professional edge with a display that features integrated color correction and has demonstrated superior fidelity in reproducing the PANTONE Matching System (PMS) Colors.
3D Lookup Tables
Get professional color grading for digital and video. 3D lookup tables (3D LUTs) map one color space to another in order to ensure faithful color reproduction.
Seamless Viewing
Creativity should never be limited, and once you’ve worked on this 27" WQHD IPS display, you’ll never settle for less. Along with an overclockable refresh rate of up to 170Hz, ConceptD CP5 series monitors give you an ultra-smooth viewing and creation experience.
A Single Port to Do It All
Easily extend the display of your laptop or mobile device, transfer data, and charge it at the same time using a single cable with the integrated USB Type-C port.
Designed for Creators
With its timeless design, ConceptD monitors easily adorn any workplace, adding a touch of class with the natural appearance of the stand base. This monitor comes with plenty of ports, a built-in light sensor, and a light shielding hood, meaning it’s equipped for professional design work.
Smart Light Sensor
Enjoy a consistently comfortable visual experience thanks to the built-in ambient light sensor. This automatically measures the brightness of the environment and adjusts the backlight accordingly, reducing eye strain.
Shaded for Accuracy
Focus in on your design work with the light-shielding hood, which ensures ambient light is blocked and you see colors more accurately. The hood reduces glare, helps relieve eye fatigue, and gives you some added privacy when you need to work on confidential projects.
Experience realistic, natural images through the expanded contrast ratio and color palette guaranteed by VESA Certified DisplayHDR 600. Create images with improved brightness and contrast with darker blacks and whiter whites with greater depth and shadowing. -
Wide Color Gamut
Get brighter and more lifelike colors with Adobe RGB 99% color gamut's extended color range. Adobe RGB is an international color standard used by directors and producers and ConceptD CP5 series monitors are designed to match this professional-grade quality, making them ideal for high-level editing of imagery and photography. -
Perfect Colors
An artist should have confidence in their tools. With Delta E Validated display, ConceptD CP5 monitors are backed up by color technologies that ensure vivid, true-to-life color reproduction. -
Seamless Viewing
Creativity should never be limited, and once you've worked on this 27" WQHD IPS display, you'll never settle for less. Along with an overclockable refresh rate of up to 170Hz, ConceptD CP5 series monitors give you an ultra-smooth viewing and creation experience. -
Easily extend the display of your laptop or mobile device, transfer data, and charge it at the same time using a single cable with the integrated USB Type-C port. -
With its timeless design, ConceptD monitors easily adorn any workplace, adding a touch of class with the natural appearance of the stand base. This monitor comes with plenty of ports, a built-in light sensor, and a light shielding hood, meaning it's equipped for professional design work.
- Acer ConceptD CP5 CP5271U Vbmiipruzx - LED monitor - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/427710
- Energy Class
- Class G
- Power Consumption (On mode)
- 32 W
- Adaptive-Sync Technology
- AMD Adaptive-Sync
- USB 3.0/USB-C hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 (DisplayPort(OC): 170 Hz, HDMI: 144 Hz, USB-C: 144 Hz)
- Brightness
- 600 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- HDR Capable
- DisplayHDR 600
- Response Time
- 1 ms (grey-to-grey), 0.7 ms (grey-to-grey min)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% Adobe RGB
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.9 cm x 30.72 cm x 44.1 cm
- 6.63 kg
- MPR II
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- AMD Adaptive-Sync
- Built-in Devices
- USB 3.0/USB-C hub
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 600 cd/m²
- Contrast Ratio
- HDR Certification
- DisplayHDR 600
- Colour Support
- Colour Gamut
- 99% Adobe RGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), 8-bit gamma, Adaptive-Sync technology, Delta E<1 calibration, Pantone Validated
- Black
- 62.9 cm x 30.72 cm x 44.1 cm - with stand
- 6.63 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 4 Watt
- 2 x HDMI , DisplayPort 1.4 , 2 x USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out (mini-jack) , USB-C (power up to 65W)
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 180 mm
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x SuperSpeed USB cable
- MPR II
- Input Voltage
- 32 W
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption HDR (On mode)
- 67 kWh/1000h
- Power Consumption (Typical)
- 36 Watt
- Power Consumption Sleep
- 0.48 Watt
- 0.38 Watt
- Dimensions & Weight Details
- With stand - width: 62.9 cm - depth: 30.72 cm - height: 44.1 cm - weight: 6.63 kg , Without stand - width: 62.9 cm - depth: 8.63 cm - height: 37.47 cm - weight: 4.44 kg
- Limited warranty - 3 years - carry-in
