Acer ConceptD 7 Ezel CC715 Intel Core i7-10875H 16GB 1TB 15.6" Windows 10 Pro White
Quicklinx: G0KJWS00 Mfr#: NX.C5AEK.001
  • Core i7
  • IEEE 802.11n
A one-stop laptop for all your creative needs. The ConceptD 7 Ezel's 4K display and multiple display modes are ideal for professional graphics artists who want to be able sketch, finalize and present on one device.
  • Elevate Your Creative Workflow
    Acer's patented Ezel Hinge gives users six modes to choose from, allowing them to easily collaborate with others in share mode, create efficiently in float mode, work on the move with stand mode, review content in pad mode, present their work in display mode, and otherwise work in peace in laptop mode.
  • Capture Inspiration
    Quickly capture that moment of inspiration with help from the Ezel Hinge's float mode, which ensures that the screen stays firmly in whatever angle or position you may work in.
  • Flexible Presentations
    Whether you're on location with a client or just in a meeting off site, easily flip the touchscreen display to face your audience for flexible presentations.
  • Maximized Productivity
    Pair your device with an external monitor to have quick and easy access to layers, colors, and other tools without having them clutter up the main display when working on your favorite apps like Adobe Photoshop.
  • Timeless Design
    The sculptured white aluminum chassis demonstrates a timeless design that is ideal for creators who need to work in fashionable locations. There is also an attractive backlit amber keyboard for working in low light conditions.
  • Backlit Keyboard
    Type comfortably in any environment with the backlit keyboard. The warm amber backlighting creates a soft radiance reminiscent of nature and a breaking dawn.
  • Ceramic Surface
    Micro-Arc Oxidation (MAO) adds an extra level of ceramic hardness, strength, and corrosion and oxidation resistance to the laptop's metal surfaces.
  • Pristine Whiteness
    The stain resistant coating protects the laptop from yellowing, and marking by materials such as dirt, markers, and coffee.
  • Precision Drawing
    By using Wacom EMR pen technology, users get the natural and intuitive feeling of drawing on paper whilst drawing on a smooth glass screen. With 4,096 levels of pressure sensitivity, the EMR pen perfectly replicates the fluidity of ink. With the digitalized design workspace, quickly send your artwork to clients, publishers, printers, or just freely distribute it to your audience.
  • Digital Sketching
    The Wacom EMR pen offers the same finesse as any of your real-world tools. Work in almost any medium, capture inspiration using your favorite software such as Autodesk SketchBook, and do what you enjoy best: create.
  • Animation
    Professional creative applications such as Adobe, Autodesk, and Corel all integrate pen recognition and Wacom pressure sensitivity to assist your work in concepting, storyboarding, character development, and more.
  • 3D Modeling
    Model, sculpt, and paint with precision. With your pressure-sensitive pen, create 3D models in applications such as Autodesk Maya with incredible detail, as if you were working with clay.
  • Pinpoint Color Accuracy
    Color accuracy is critical for design and the ConceptD 7 Ezel doesn't disappoint with its 4K UHD PANTONE Validated display. Faithful color reproduction is ensured with a 100% Adobe RGB color gamut and a color accuracy of Delta E Gorilla Glass 6 display.
  • 100% Adobe RGB Color Gamut
    With 100% Adobe RGB, colors will be brighter and more accurate due to extending the color range of cyan-green hues. The Adobe RGB gamut covers a wider range of colors than an sRGB gamut.
  • PANTONE Validated
    Get a professional edge with a display that features integrated color correction and has demonstrated superior fidelity in reproducing the PANTONE Matching System (PMS) Colors.
  • Delta E <2
    The display has been tested and calibrated to achieve a low Delta E average of <2 to reproduce true-to-life color accuracy.
  • Independent Software Vendors (ISV)
    To meet the demands of engineers, architects, videographers, cinematographers, 3D animators, AI professionals and many more, a hardware solution that has been tested and certified by Independent Software Vendors (ISVs) is demanded. ConceptD products, in specific model configurations, offer ISV certified hardware in combination with the most recent technologies.
  • Optimized Thermals- Vortex Flow
    A quiet and comfortable environment is vital when you're focusing on an important piece of design. The combination of the 4th Gen AeroBlade 3D fans and our latest thermal cooling technology generates a unique aerodynamic'Vortex Flow' within the device to both reduce noise levels to less than 40dBA and ensure the device and the components inside stay frosty even when pushed to the limit.
  • Bionic Design
    Inspired by silent, powerful owl flight mechanics we gave our fans a serrated edge, allowing more air to pass through.
  • Ultra-thin Blades
    Each of the 59 bionic blades is just 0.1mm thick and all-metal with a stabilizing dual indent groove.
  • Noise Reduction
    The winglets' noise-reducing mechanism, along with the optimized thermal tuning system, further reduce turbulence and give you a quiet, comfortable place for creation.
  • Performance Control
    Flexibly control your ConceptD laptop's performance by switching between full performance, balanced, and whisper-quiet ECO modes.
  • Screen Split Functionality
    Automatically arrange your on-screen applications for maximum efficiency without needing to manually adjust window size.
  • Snipping& Clipboard Tools
    Enable easy-to-use, OS-integrated screen snipping and clipboard tools for even greater creative functionality.
Acer ConceptD 7 Ezel CC715-71-73RW - 15.6" - Intel Core i7 - 10875H - 16 GB RAM - 1.024 TB SSD - UK
Notebook - slider
Operating System
Win 10 Pro 64-bit
Intel Core i7 (10th Gen) - 10875H / 2.3 GHz, up to 5.1 GHz / 16 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
1.024 TB SSD
Display
15.6" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA GeForce RTX 2070
Video Memory
8 GB GDDR6 SDRAM
Input Device
Digitizer, digital pen
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet
4-cell - up to 8 hours
Security
Fingerprint reader
The white
35.85 cm x 26 cm x 2.86 cm
2.5 kg
Region: United Kingdom
Limited warranty - 3 years - carry-in
Notebook - slider
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10875H / 2.3 GHz
Max Turbo Speed
5.1 GHz
Number of Cores
8-core
Cache
16 MB
64-bit Computing
Chipset
Intel HM470
Intel Thermal Velocity Boost
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1.024 TB SSD
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Colour Gamut
100% Adobe RGB
Anti-glare, ComfyView, 30 ms response rate, Delta E<2 calibration, Corning Gorilla glass 6, Pantone Matching System (PMS)
Audio & Video
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Camera
Yes - HD
Camera Features
Windows Hello
Sound
Stereo speakers, two microphones
Input
Keyboard, digitizer, touchpad, digital pen
Keyboard Backlight
Keyboard Layout
Acer FineTip keyboard, Wacom EMR technology, Corning Gorilla Glass touchpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 2230
Network Interface
Gigabit Ethernet
Wake-on-LAN (WOL)
4-cell Lithium Ion
84 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
230 Watt, 19.5 V
Connections & Expansion
Interfaces Details
HDMI , DisplayPort , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) , USB 3.1 Gen 1 (with power off charging) , USB 3.1 Gen 1 , LAN , Headphone/microphone combo jack
The white
Security
Fingerprint reader
Dual Acer AeroBlade 3D Fans
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, Wacom pen
Localization
2.5 kg
Sustainability Information
TCO Certified
