Acer ConceptD 3 Ezel CC315 Intel Core i7-10750H 16GB 1TB 15.6" Windows 10 Pro White
Quicklinx: G0K8WS00 Mfr#: NX.C5QEK.001
  • Core i7
  • IEEE 802.11n
Creativity can happen anywhere, and ConceptD has you covered. The ConceptD 3 Ezel Pro is the versatile and creative toolbox designed for creators on the go. Fully convertible, lightweight, and with a PANTONE Validated touchscreen display which comes with its own dockable stylus, enjoy a next-level creative process wherever your heart takes you along the way.
  • Flexibility in creation
    Acer's innovative Ezel hinge gives you six convertible modes to choose from, allowing you to easily create, collaborate, and share in whichever mode you choose.
  • Optimized thermals - Vortex Flow
    High performance doesn't need to mean a hot-running machine or loud, annoying fans. The dual, high-efficiency fans and Acer's thermal cooling technology work together to generate a unique aerodynamic Vortex Flow which reduces noise levels to less than 40dBA and ensures all the components inside the device stay cool even when under heavy load.
  • Reliable, amber-lit keystrokes
    The full-sized keyboard features media-focused hotkeys that allow you to readily crop images or swap color profiles while the softly glowing amber backlight ensures you can still get things done quickly and easily in even the darkest of rooms.
  • Secure login with a single touch
    Sign in to your laptop your own way. Featuring password-free Windows Hello login, effortlessly access your device with the fingerprint reader that's built directly into the power button.
Acer ConceptD 3 Ezel Pro CC315-72P-74ZN - 15.6" - Intel Core i7 - 10750H - 16 GB RAM - 1.024 TB SSD - UK
Notebook - slider
Operating System
Win 10 Pro 64-bit
Intel Core i7 (10th Gen) - 10750H / 2.6 GHz, up to 5 GHz / 12 MB Cache
16 GB DDR4
Storage
1.024 TB SSD - SED
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro T1000
Video Memory
4 GB GDDR5 SDRAM
Input Device
Digitizer, digital pen
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
Up to 14 hours
Accelerometer
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
The white
35.85 cm x 24.9 cm x 1.89 cm
2.2 kg
Region: United Kingdom
1.12 W/kg (head) , 1.12 W/kg (body) , 1.12 W/kg (limb)
Limited warranty - 3 years - carry-in
Notebook - slider
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10750H / 2.6 GHz
Max Turbo Speed
5 GHz
Number of Cores
6-core
Cache
12 MB
64-bit Computing
Chipset
Intel HM470
Intel Smart Cache, Intel Turbo Boost Max Technology 3.0
RAM
16 GB
DDR4 SDRAM
Storage
Main Storage
1.024 TB SSD PCIe - Self-Encrypting Drive - Samsung
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
340 cd/m²
Anti-glare, ComfyView, 25 ms response rate, Corning Gorilla glass 6
Audio & Video
Graphics Processor
NVIDIA Quadro T1000
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 1280 x 720
Camera Features
Windows Hello
Sound
Stereo speakers, two microphones
Input
Keyboard, digitizer, touchpad, digital pen
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Corning Gorilla Glass touchpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 2230
Network Interface
Gigabit Ethernet
Lithium Ion
56 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
135 Watt, 19.5 V
Connections & Expansion
Interfaces Details
HDMI , Mini DisplayPort , USB-C 3.2 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , USB 3.2 Gen 1 (with power off charging) , USB 3.2 Gen 1 , Headphone/microphone combo jack , LAN
The white
Case Material
Magnesium-aluminum alloy
Integrated Options
Accelerometer
Security
HDCP Compliant
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, Acer Active Stylus
SAR Value
1.12 W/kg (body), 1.12 W/kg (limb), 1.12 W/kg (head)
Localization
2.2 kg
Sustainability Information
TCO Certified
