The ConceptD 700 workstation is ideal for filmmakers, animators and AEC (architecture, engineering, construction) designers. The elegant and robust ConceptD 700 workstation was built to handle heavy content creator workflows with ease. Optimal thermal ventilation is critical for taking on heavy design rendering. The ConceptD 700 uses three efficient cooling fans to draw air in through the triangular-patterned front air panel and then circulates it throughout the chassis. To help keep the work area tidy and functional, the workstation offers fast wireless charging for smartphones on its topside, plus cable management and a pop-out headset cradle that can be tucked away when not in use.
ConceptD 700
Built to Create -
Optimal Performance Workstation
Optimized for 2D/3D CAD, BIM design and photorealistic models in real-time, the ConceptD 700 is powered by the latest Intel Xeon processor with 3.7 GHz, 8 cores 16 threads, and optional Optane memory. Combined with the Intel Xeon processor's ECC memory support, the ConceptD 700 provides the speed and system reliability that professional creators demand in addition to the high performance needed for large CAD, BIM, and video production workloads. -
Create Without Boundaries
Supporting a maximum of an NVIDIA Quadro RTX 4000 graphics, the ConceptD 700 provides unmatched power for unmatched creative freedom in areas like 3D modeling design and visualization AI-powered workflows. Enjoy greater fluidity with photorealistic ray-tracing; experience faster performance with AI-enabled applications and create detailed, lifelike VR experiences. -
Amazing Performance
NVIDIA Turing architecture combined with NVIDIA RTX technology brings real-time ray-tracing to professional workstation users. -
Advanced Display Features
Experience stunning image quality with the power to drive up to four 8K displays with HDR support via Display Port 1.4. HDR supports twice the visible colors for brighter, more saturated images. -
Immersive VR
The Quadro RTX 4000 is specially designed with the performance that is necessary to drive immersive VR environments, enabling the most detailed, life-like VR experience possible. -
Optimized Quiet Cooling
Processor intensive applications such as rendering and video production will cause the processor and GPU to run hot, therefore it's essential that the cooling is the best it can be. The ConceptD 700 has optimal thermal, ventilation, airflow dynamics and is cooled using three cooling fans to draw the air in through the triangular front air panel and circulating it throughout the chassis. And yet, at just 40dBA it is still quiet enough to be unobtrusive. -
Elegantly Honest
Designed to fit into any modern studio, the ConceptD 700 has a round-cornered white minimalist design with a wood effect top and triangular front panel. Beyond the simple aesthetic is an array of thoughtful and practical functions, such as convenient wireless charging and an array of high speed connecting ports. At the front is an integrated amber light which gives a sense of warmth. -
Wireless Charging
Fast charge your modern Qi-compatible devices without the need to plug your device into a wall -
Headset Cradle
The thoughtfully designed push pop-out design gives freedom to use and tuck it away when not in use. -
Cable Management
Maintain clean and neat look from behind, sort messy cables. -
Impressive Expandability
Expandable workstation designed to grow with you to meet your ever-changing workload requirements. Quickly access and store massive amounts of data and files with flexible storages options. -
Quicker Response
4 x DIMM 2666 MHz DDR4 memory up to 64GB has more bandwidth and capacity. Experience fast performance when working on complex design tasks. -
Ultrafast PCIe Interface
Work with large models and render complex 3D models in real time with bigger, faster storage options include onboard PCIe M.2 SSD. -
Tool-less HDD Drive
Quickly access and store massive amounts of data and files with two storage bays supporting 3.5" HDDs. -
Independent Software Vendors (ISV)
To meet the demands of engineers, architects, videographers, cinematographers, 3D animators, AI professionals and many more, a hardware solution that has been tested and certified by Independent Software Vendors (ISVs) is demanded. ConceptD products, in specific model configurations, offer ISV certified hardware in combination with the most recent technologies. -
Secure and Manageable Workstation
The ConceptD 700 has a host of features designed to keep your data and machine safe from failure. -
Health Indicator Light
For quick trouble-shooting, the health indicator displays warning indications via the power button and amber LED light. -
Intrusion Key Lock
The system comes with a lock and an intrusion alarm to prevent theft and unauthorized access. -
ConceptD Palette
Quickly and easily monitor your system CPU, GPU, and memory usage through the intuitive ConceptD Palette.
- Acer ConceptD 700 CT700-71A - tower - AI Ready - Xeon E-2226G 3.4 GHz - 32 GB - SSD 1.024 TB, HDD 1 TB
- Workstation - tower AI Ready
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Xeon E-2226G / 3.4 GHz (, up to 4.7 GHz, (6-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 32 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- SATA
- Hard Drive
- SSD 1.024 TB - Self-Encrypting Drive
- Hard Drive (2nd)
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- PCIe x16 - NVIDIA Quadro P4000
- Video Memory
- 8 GB GDDR5 SDRAM
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Power
- AC 120/230 V
- OS Provided
- Windows 10 Pro 64-bit Edition
- 20.4 cm x 47.6 cm x 43.9 cm
- 9 kg
- Limited warranty - 3 years - carry-in
- Workstation - AI Ready
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E-2226G
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C246
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 16 GB
Hard Drive
- SSD
- Capacity
- 1 x 1.024 TB
- Manufacturer
- Samsung
Hard Drive (2nd)
- HDD
- Interface Class
- Serial ATA
- Capacity
- 1 x 1 TB
- Manufacturer
- Seagate
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe x16
- Graphics Processor
- Video Memory
- 8 GB GDDR5 SDRAM
- Video Interfaces
- DisplayPort
- Ethernet Controller
- Intel I219-LM, I211-AT
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Remote Management Protocol
- DMI
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Slots
- 2 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI , 2 M.2 Card
- 3 x USB 3.1 Gen 2 (2 rear, 1 top) , 4 x USB 2.0 (2 top, 2 rear) , 1 x USB-C 3.1 Gen 2 (1 top) , 4 x DisplayPort , 2 x USB 3.1 Gen 1 , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet)
- Included Accessories
- 2x wireless aerials, thermal pad
- BSMI, CB, RoHS, PC 2001
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 500 Watt
- Efficiency
- 87%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 20.4 cm
- 47.6 cm
- 43.9 cm
- 9 kg
APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt | In Stock | £439.01 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £202.53 |
APC BACK UPS PRO BR1300MI 1300VA 8 Outlets | In Stock | £298.60 |
APC BACK UPS PRO BR1600MI 1600VA 8 Outlets | In Stock | £357.34 |
