Acer Concept D 700 Xeon E-2224G 64GB 1TB HDD+1TB Win10P
Quicklinx: G553WS00 Mfr#: DT.C04EK.003
  • Xeon
  • IEEE 802.11n
The ConceptD 700 workstation is ideal for filmmakers, animators and AEC (architecture, engineering, construction) designers. The elegant and robust ConceptD 700 workstation was built to handle heavy content creator workflows with ease. Optimal thermal ventilation is critical for taking on heavy design rendering. The ConceptD 700 uses three efficient cooling fans to draw air in through the triangular-patterned front air panel and then circulates it throughout the chassis. To help keep the work area tidy and functional, the workstation offers fast wireless charging for smartphones on its topside, plus cable management and a pop-out headset cradle that can be tucked away when not in use.
  • ConceptD 700
    Built to Create
  • Optimal Performance Workstation
    Optimized for 2D/3D CAD, BIM design and photorealistic models in real-time, the ConceptD 700 is powered by the latest Intel Xeon processor with 3.7 GHz, 8 cores 16 threads, and optional Optane memory. Combined with the Intel Xeon processor's ECC memory support, the ConceptD 700 provides the speed and system reliability that professional creators demand in addition to the high performance needed for large CAD, BIM, and video production workloads.
  • Create Without Boundaries
    Supporting a maximum of an NVIDIA Quadro RTX 4000 graphics, the ConceptD 700 provides unmatched power for unmatched creative freedom in areas like 3D modeling design and visualization AI-powered workflows. Enjoy greater fluidity with photorealistic ray-tracing; experience faster performance with AI-enabled applications and create detailed, lifelike VR experiences.
  • Optimized Quiet Cooling
    Processor intensive applications such as rendering and video production will cause the processor and GPU to run hot, therefore it's essential that the cooling is the best it can be. The ConceptD 700 has optimal thermal, ventilation, airflow dynamics and is cooled using three cooling fans to draw the air in through the triangular front air panel and circulating it throughout the chassis. And yet, at just 40dBA it is still quiet enough to be unobtrusive.
  • Elegantly Honest
    Designed to fit into any modern studio, the ConceptD 700 has a round-cornered white minimalist design with a wood effect top and triangular front panel. Beyond the simple aesthetic is an array of thoughtful and practical functions, such as convenient wireless charging and an array of high speed connecting ports. At the front is an integrated amber light which gives a sense of warmth.
  • Impressive Expandability
    Expandable workstation designed to grow with you to meet your ever-changing workload requirements. Quickly access and store massive amounts of data and files with flexible storages options.
  • Independent Software Vendors (ISV)
    To meet the demands of engineers, architects, videographers, cinematographers, 3D animators, AI professionals and many more, a hardware solution that has been tested and certified by Independent Software Vendors (ISVs) is demanded. ConceptD products, in specific model configurations, offer ISV certified hardware in combination with the most recent technologies.
  • Secure and Manageable Workstation
    The ConceptD 700 has a host of features designed to keep your data and machine safe from failure.
Acer ConceptD 700 CT700-71A - tower - AI Ready - Xeon E-2224G 3.5 GHz - 32 GB - SSD 1.024 TB, HDD 1 TB
Workstation - tower AI Ready
Region: United Kingdom
1 x Intel Xeon E-2224G / 3.5 GHz (, up to 4.7 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
32 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA
Hard Drive
SSD 1.024 TB - Self-Encrypting Drive
Hard Drive (2nd)
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Card Reader
Graphics Controller
PCIe x16 - NVIDIA Quadro P2200
Video Memory
5 GB GDDR5X SDRAM
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
20.4 cm x 47.6 cm x 43.9 cm
9 kg
Limited warranty - 3 years - carry-in
Workstation - AI Ready
Product Form Factor
Tower
Processor / Chipset
CPU
Intel Xeon E-2224G
Clock Speed
3.5 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel C246
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Unbuffered, dual channel memory architecture
Configuration Features
2 x 16 GB
Hard Drive
SSD
1 x 1.024 TB
Manufacturer
Samsung
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Manufacturer
Seagate
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe x16
Graphics Processor
NVIDIA Quadro P2200
Video Memory
5 GB GDDR5X SDRAM
Video Interfaces
DisplayPort
Ethernet Controller
Intel I219-LM, I211-AT
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Remote Management Protocol
DMI
Slots
2 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI , 2 M.2 Card
3 x USB 3.1 Gen 2 (2 rear, 1 top) , 4 x USB 2.0 (2 top, 2 rear) , 1 x USB-C 3.1 Gen 2 (1 top) , 4 x Mini DisplayPort , 2 x USB 3.1 Gen 1 , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet)
2x wireless aerials, thermal pad
BSMI, CB, RoHS, PC 2001
Power supply
AC 120/230 V
Power Provided
500 Watt
Efficiency
87%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
20.4 cm
47.6 cm
43.9 cm
9 kg
G553 APC Power Saving Back-UPS Pro 1500 In Stock £371.62
G553 APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt In Stock £438.01
G553 APC BACK UPS PRO BR900MI 900VA 6 Outlets In Stock £204.72
G553 APC BACK UPS PRO BR1300MI 1300VA 8 Outlets In Stock £294.00
G553 APC BACK UPS PRO BR1600MI 1600VA 8 Outlets In Stock £360.93
