Acer Concept D 100 Intel Core i5-9400F 16GB 1TB HD+512GB Win10P
Quicklinx: G54XWS00 Mfr#: DT.C05EK.006
  • Core i5
  • IEEE 802.11n
Designed for professional creators and multimedia classrooms, this compact desktop is ideal for enabling graphics-intensive 2D design and entry-level 3D CAD modeling.
  • ConceptD 100
    Unlock Creativity
  • Professional Content Creation
    Equipped to handle 2D and light-duty 3D computer-aided (CAD) workloads in fields such as architecture and engineering, the ConceptD 100 is powered by the latest 9th Generation Intel Core i5 processor to enable smooth and responsive multitasking performance while making sure applications and projects run faster with even more stability.
  • Create Without Boundaries
    As content creation becomes more complex, visual effects grow in size, complexity, and scope. The NVIDIA Quadro P620 graphics card provides optimized stability and performance for professional 2D and 3D applications to accelerate everyday creative workflow.
  • Pascal Architecture
    The revolutionary NVIDIA Pascal architecture is purpose-built to be the engine of computers that learn, see, and simulate our world.
  • NVIDIA Quadro GPU
    Designed, built and tested by NVIDIA, Quadro desktop products are the#1 choice of millions of creative and technical users.
  • A Boost in Productivity
    Work your way through projects quicker than ever before. Experience fast response times with up to 32GB DDR4 memory combined with high-performance Intel Optane Memory, while also quickly accessing massive amounts of data with flexible storage options including a 256GB M.2 PCIe SSD and up to 2TB 3.5" HDDs.
  • Unassuming Efficiency
    With the ConceptD 100's small stature and the white, round-cornered minimalist design, this unobtrusive and space-saving small form factor (SFF) creator desktop is specially designed to fit easily into any modern office or studio.
  • Silent Focus
    A quiet environment is vital when you're focusing on an important piece of design. With its front air intake and side ventilation, this workstation is optimized for both cooling and reduced noise levels of less than 40 dbA, the equivalent of a library room.
  • Independent Software Vendors (ISV)
    To meet the demands of engineers, architects, videographers, cinematographers, 3D animators, AI professionals and many more, a hardware solution that has been tested and certified by Independent Software Vendors (ISVs) is demanded. ConceptD products, in specific model configurations, offer ISV certified hardware in combination with the most recent technologies.
  • Complete Connectivity
    Hook up all your peripherals and accomplish more with a full range of ports, including a USB Type-C port for 10Gbps data transfer and connecting to multiple 4K displays whilst also being able to charge peripherals offline. The integrated SD card reader lets you easily transfer files while the multiple USB 3.1 Gen2 ports allow for quick peripheral access.
Acer ConceptD 100 CM100-51A - SFF - AI Ready - Core i5 9400F 2.9 GHz - 16 GB - SSD 512 GB, HDD 1 TB
Workstation - SFF AI Ready
Region: United Kingdom
1 x Intel Core i5 (9th Gen) 9400F / 2.9 GHz (, up to 4.1 GHz, (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 512 GB
Hard Drive (2nd)
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Card Reader
Graphics Controller
PCIe x16 - NVIDIA GeForce GT 1030
Video Memory
2 GB GDDR5 SDRAM
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
AC 230V
OS Provided
Windows 10 Pro 64-bit Edition
10 cm x 33 cm x 29.5 cm
5.5 kg
Limited warranty - 3 years - carry-in
Workstation - AI Ready
Product Form Factor
SFF
Processor / Chipset
CPU
Clock Speed
2.9 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Unbuffered
Configuration Features
2 x 8 GB
Hard Drive
SSD
1 x 512 GB
Manufacturer
Kingston
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Manufacturer
Seagate
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe x16
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video Interfaces
DVI, HDMI
Ethernet Controller
Realtek RTL8111GA
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9462
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Bays
Internal 3.5"
Slots
1 (total) / 0 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1
USB 3.1 Gen 2 (1 in front) , USB-C (1 in front) , Audio line-in , Audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x HDMI
2x wireless aerials, thermal pad
EuP
Power supply
AC 230V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
10 cm
33 cm
29.5 cm
5.5 kg
Sound Emission
40 dBA
G54X APC Back-UPS CS 650VA In Stock £141.63
G54X APC BACK-UPS BE650G2-UK 650VA 230V In Stock £107.39
G54X APC BACK-UPS BE850G2-UK 850VA 230V USB In Stock £119.96
G54X APC BACK UPS PRO BR650MI 650VA 6 Outlets In Stock £152.26
G54X APC BACK UPS PRO BR900MI 900VA 6 Outlets In Stock £209.11
G54X APC Back-UPS CS 500Ei In Stock £120.31
