Crisp, clear, perfect, visuals are displayed on the high-resolution screen with a 178° viewing angle. With a high-resolution display, movies and TV shows are shown in great clarity, and then share the screen with those around you with the expansive viewing angle.
The Power to Perform
When you're on the go, you need a laptop that can keep up with you. With a 10th Gen Intel Core i7 processor, this Chromebook can be woken up from sleep in less than a second while also boasting a 10-hour battery life.
- Acer Chromebook Spin 713 CP713-2W-57XG - 13.5" - Intel Core i5 - 10210U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS (with Chrome Enterprise Upgrade)
- Processor
- Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (8 GB (soldered))
- Storage
- 256 GB SSD
- Display
- 13.5" LED backlight touchscreen 2256 x 1504
- Graphics
- Intel UHD Graphics
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
- Battery
- Up to 10 hours
- Accelerometer, gyro sensor
- Steel grey
- 30.065 cm x 23.5 cm x 1.68 cm
- 1.37 kg
- Localisation
- Region: United Kingdom
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Operating System
- Google Chrome OS (with Chrome Enterprise Upgrade)
Processor / Chipset
- CPU
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (8 GB (soldered))
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
Storage
- Main Storage
- 256 GB SSD - SanDisk
Display
- 13.5" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2256 x 1504
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 415 cd/m²
- Corning Gorilla glass, glare, CineCrystal, 30 ms response rate
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 1216
- Technology
- Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- HDMI , 2 x USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) , USB 3.0 , Headphone/microphone combo jack
- Steel grey
- Integrated Options
- HDCP Compliant
- Included Accessories
- USB-C power adapter
- MIL-STD 810G
- Localization
- 1.37 kg
Sustainability Information
- TCO Certified
