With a 3:2 aspect ratio display, there's more vertical screen space to read information on the 10-point multi-touch screen. Viewing websites and documents now needs less scrolling. Low power usage and responsive software are provided by a powerful processor. The extra performance makes highly graphical classroom projects run smoother so tasks are performed quicker. The impact-resistant body stands up to daily wear and tear. The shock-absorbent bumper and reinforced design protect components.
Military-Grade Durability
The Military Standard (MIL-STD 810G) tested, impact-resistant body stands up to daily wear and tear. It can take a 60-kg weight, the shock-absorbent bumper and reinforced design protect components and it can survive drops from 122cm. The unique drainage design means 330ml of liquid can be spilled over the keyboard.
- Acer Chromebook Spin 512 R852T-C0E1 - 12" - Intel Celeron - N4020 - 4 GB RAM - 32 GB eMMC - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N4020 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache
- Memory
- 4 GB LPDDR4 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 12" LED backlight touchscreen 1366 x 912 / HD+
- Graphics
- Intel UHD Graphics 600
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
- Battery
- 3-cell
- Gyro sensor
- Security
- Google Security Chip H1
- Shale black
- 29.6 cm x 23.11 cm x 2.03 cm
- 1.55 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- TCO Certified Notebooks 8
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR4 SDRAM
Storage
- Main Storage
- 32 GB eMMC - Kingston
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 912 (HD+)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 235 cd/m²
- Colour Gamut
- 50% NTSC
- CineCrystal, 25 ms response rate
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 88° view
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 2230
- Technology
- 3-cell Lithium Ion
- Capacity
- 45 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- 2 x USB-C (DC-In combo) , 2 x USB 3.2 Gen 1 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDXC)
- Shale black
- Case Material
- Polycarbonate ABS
- Integrated Options
- Gyro sensor
- Security
- MU-MIMO technology, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.55 kg
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 8
