Slip the Acer Chromebook into your bag and work from anywhere. At less than an inch thin and extremely light, the Acer Chromebook is the perfect tool for on-the-go computing.
Amazing mobility
Slip the Acer Chromebook into your bag and work from anywhere, without recharging, because it has enough battery life to last all day long on a single charge. -
Vivid display
Indulge your eyes and see everything in vivid detail on the Acer Chromebook's HD display. -
The quickest connection
The Acer Chromebook features wireless technology for a smooth Internet experience at connection speeds. -
Fast boot-up
The Acer Chromebook starts within few seconds, so you can wait less and do more. -
Sleek design
At less than an inch thin and extremely light, the Acer Chromebook is the perfect tool for on-the-go computing. Plus, it sports a fan-less design for whisper-quiet computing.
- Acer Chromebook CB3-111-C61U - 11.6" - Intel Celeron - N2830 - 2 GB RAM - 16 GB eMMC
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Celeron N2830 / 2.16 GHz, up to 2.41 GHz / 1 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac
- Battery
- 3-cell - up to 8 hours
- White
- 29.9 cm x 20.2 cm x 1.865 cm
- 1.25 kg
- Localisation
- Region: United Kingdom
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.41 GHz
- Number of Cores
- Dual-Core
- Cache
- 1 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- 802.11a/b/g/n/ac
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Technology
- 3-cell Lithium Ion
- Capacity
- 36 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- White
- MIMO technology
- Included Accessories
- Power adapter
- Localization
- 1.25 kg
