Acer CB514-1H Pentium N4200 4GB 32GB 14" Chrome OS
Quicklinx: FYG1WS00 Mfr#: NX.H1QEK.004
  • Pentium
  • IEEE 802.11n
The Acer Chromebook 514 has everything you'd expect and then gives you more. For one thing, it's completely encased in aluminum alloy. Then you get a bigger 14-inch anti-glare screen, long-lasting battery life and enhanced wireless speeds. It's absolutely stunning.
  • Stylish Yet Tough
    Strength, durability and stylish good looks are provided through the aluminium chassis. The strong lightweight metal chassis means that it is less likely to be bent, warped or dented than other materials.
  • Designed To Be Seen
    The narrow bezel allows a 14" screen in a smaller footprint. Thanks to the 6mm narrow bezel and wide viewing angle of the Full HD IPS screen, you can enjoy the full majesty of films, videos and TV shows. An optional touch screen makes it easy to navigate and control videos on the 1920x1080 resolution display with 2,073,600 pixels display.
  • Day or Night Keyboard
    Backlit keyboards not only look pretty but they also allow users to type comfortably in dimly lit environments. When individual keys are lit up it's easy to see them when there's no other light source.
  • Tougher, Smoother Touch
    Tapping, swiping, scrolling and zooming are smoother than ever. The Corning Gorilla touchpad provides a slicker feel than a regular plastic touchpad, and gives users the confidence that it won't break. With the ability to withstand scratches and pits it will continue to look as slick as the day you bought it.
  • All-day Battery Life
    Up to 12 hours of battery life goes a long way. With just a single charge, get in a full day's work, study or play with time to spare. The powerful long-lasting battery means you don't have to take the power adapter with you.
  • One Port, Many Uses
    One connector is used for ultra-quick data transfer, video streaming and battery charging. The reversible USB 3.1 Type-C ports are easy to attach to and, with a transfer rate up to 5Gb/sec, are 10 times faster than USB 2.0.
  • Stay Productive
    With Chrome OS you can still use your favourite software. Traditional office productivity programs like Microsoft Office and Skype have Chrome versions, as too do Facebook and Instagram. And if your favourite isn't there you can download many more equivalent programs from Google Play.
  • Polished Performance
    Fast boot times, ease of use, tough security and a long battery life are some of the advantages of Chrome OS. With a fast boot time, you'll start working quicker; the simplified interface makes it easy to learn; integrated malware protection stops viruses in their tracks; and finally, an efficient use of power means that you can work all day without your power adapter.
  • Greater Camera Clarity
    Give your audience an even clearer view of the subject with the HDR webcam. With the crystal-clear clarity and sharpness of HDR, the subject in front of the camera is always shown in brilliant detail.
Acer Chromebook 514 CB514-1H-P09A - 14" - Intel Pentium - N4200 - 4 GB RAM - 32 GB eMMC - UK
Chromebook
Operating System
Chrome OS
Intel Pentium N4200 / 1.1 GHz, up to 2.5 GHz / 2 MB Cache
4 GB LPDDR4
Storage
32 GB eMMC
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 505
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell - up to 12 hours
Pure silver
32.3 cm x 23.2 cm x 1.695 cm
1.5 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - carry-in ¦ International travellers warranty - 1 year
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB
LPDDR4 SDRAM
Storage
Main Storage
32 GB eMMC - SanDisk
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, ComfyView, Narrow Border Display
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
3-cell lithium polymer
45 Wh
Run Time
Up to 12 hours
AC Adapter
Input
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) , 2 x USB 3.0 , Headphone/microphone combo jack
Pure silver
Fanless, MIMO technology
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
Localization
1.5 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
