Acer CB271HAbmidr 27" 1920x1080 4ms VGA DVI HDMI Monitor
Quicklinx: CP96WS00 Mfr#: UM.HB1EE.A01
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£130.73 ex VAT
£156.87 inc VAT
  • Visually outstanding
    CB1 series monitors combine multiple features and technologies to produce a superior visual experience. With high resolutions, wide viewing angles and added color and clarity enhancement technologies, it's a beautiful view.
  • Protective comfort
    CB1 displays are a bonanza of features that both improve your viewing experience and help reduce eye strain. The flicker-less display has blue light filter and glare reduction features that significantly improve viewing comfort while enhancing eye protection.
  • Usability enhancements
    All CB1 monitors have enhanced ergonomics thanks to the clever design of their supporting ErgoStand, which enables a wide range of tilt, swivel and height adjustments. With the ErgoStand, you can adjust the display to practically any position and purpose.
Acer CB271H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Screen Coating
Anti-glare
64 cm x 23.7 cm x 55.2 cm
7.33 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays
3-year warranty
Display Type
Energy Class
Class B
60 kWh
41 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, ErgoStand, picture by picture, Acer EcoDisplay, 72% NTSC colour gamut, High Frame Rate Control (Hi-FRC), 6-axis colour adjustment, 6-bit gamma, EyeProtect
64 cm x 23.7 cm x 55.2 cm - with stand
7.33 kg
Audio
Speakers
VGA , DVI , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
VESA 100 x 100 mm
1 x VGA cable , 1 x DVI cable
TCO Displays
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.4 kg , With stand - width: 64 cm - depth: 23.7 cm - height: 55.2 cm - weight: 7.33 kg
ENERGY STAR Certified
Limited warranty - 3 years
Acer CB271HAbmidr 27 Bundle deal on Acer CB271HAbmidr 27" 1920x1080 4ms VGA DVI HDMI Monitor
£230.49
Diagonal Size: 27in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
