Acer CB271H 27" 1920x1080 1ms HDMI DVI VGA LED Monitor
Quicklinx: CLZ9WS00 Mfr#: C9TG
The Acer CB Series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
  • Visually outstanding
    CB1 series monitors combine multiple features and technologies to produce a superior visual experience. With high resolutions, wide viewing angles and added color and clarity enhancement technologies, it's a beautiful view.
  • Protective comfort
    CB1 displays are a bonanza of features that both improve your viewing experience and help reduce eye strain. The flicker-less display has blue light filter and glare reduction features that significantly improve viewing comfort while enhancing eye protection.
  • Usability enhancements
    All CB1 monitors have enhanced ergonomics thanks to the clever design of their supporting ErgoStand, which enables a wide range of tilt, swivel and height adjustments. With the ErgoStand, you can adjust the display to practically any position and purpose.
Acer CB271H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
64 cm x 23.7 cm x 55.2 cm
7.33 kg
Environmental Standards
ENERGY STAR Qualified
FCC Part 15, WEEE, Directive 1275/2008, Directive 2009/125/EC, EN 50564:2011, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, IEC 62301:2011, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
3-year warranty
Display Type
Energy Class
Class B
60 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
1 ms
Backlight Technology
LED backlight
ErgoStand, picture by picture, frameless, Zero Frame, 6-axis colour adjustment
64 cm x 23.7 cm x 55.2 cm - with stand
7.33 kg
Audio
Speakers
VGA , DVI , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
Acer Eyeprotect technology
1 x VGA cable , 1 x DVI cable
41 W
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.4 kg , With stand - width: 64 cm - depth: 23.7 cm - height: 55.2 cm - weight: 7.33 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
