The Acer Prosumer series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
Great details
This monitor provides stunning image quality and sharp details with UHD, WQHD and FHD high resolution. This monitor also has color adjustment to meet the highest standard in color accuracy. With the clear view provided by these monitors, you can see work clearer and get jobs done quicker. -
Seamless visuals
Wide viewing angles preserve image clarity for better views all around. Their wide color gamut presents more colors on the screen. Flicker-less technology combined with a quick response time removes screen flicker and renders images faster. What's more, Acer ComfyView technology reduces reflections to provide more comfort for your eyes. -
Enhanced usability
These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ErgoStand that allows you to adjust the viewing angle for maximum comfort. You can seamlessly expand your view across multiple monitors thanks to a Zero Frame design, or see more on the same screen with picture-in-picture and picture-by-picture technologies. -
Eco-friendly
This monitor is RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. This monitor meets several international standards for green technology.
- Acer CB270HU - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 61 kWh
- Daisy Chaining
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DVI, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black glossy with silver ring on footstand
- 63.97 cm x 24.47 cm x 55.81 cm
- 7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II, TUV, GS, ISO9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 61 kWh
- Diagonal Size
- 27"
- Daisy Chaining
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 108.8
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- 6 ms
- Vertical Refresh Rate
- 23 - 76 Hz
- Horizontal Refresh Rate
- 15 - 99 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- ErgoStand, Acer EcoDisplay, ComfyView, Hard Coating (3H)
- 7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DisplayPort , HDMI , DVI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x DVI cable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 28.4 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 400 mW
- Dimensions & Weight Details
- With stand - width: 63.97 cm - depth: 24.47 cm - height: 55.81 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
