This monitors provide stunning image quality and sharp details. They also have color adjustment to meet high color accuracy. With the clear view provided by these monitors, you can work clearer and get the job done quicker.
Great details
These monitors provide stunning image quality and sharp details with FHD high resolution. These monitors also have 6-axis color adjustment to meet the highest standard in color accuracy. With the clear view provided by these monitors, you can see work clearer and get jobs done quicker. -
Enhanced usability
These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ErgoStand that allows you to adjust the viewing angle for maximum comfort. -
Eco-friendly
CB Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting.
- Acer CB241HYbmdpr - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 54.1 cm x 21.7 cm x 37.6 cm
- 5.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Pixel Per Inch
- 92.6
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, ComfyView, Zero Frame, Flicker-Less technology, Bluelight Filter
- Black
- 5.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- VGA , DVI , DisplayPort
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 60
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
- MTBF
- 30,000 hour(s)
- Power Consumption (Typical)
- 20.8 watt
- Power Consumption Sleep
- 0.48 watt
- 0.38 watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
