Acer CA24I2 Ci58250U 8GB 128GB SSD 23.8" Chrome OS
Quicklinx: FYFVWS00 Mfr#: DQ.Z0YEK.001
  • Core i5
  • IEEE 802.11n
The big screen features high resolution and IPS technology, for crystal-clear images, that show every detail to all your team members - even when they're viewing from wide angles.
  • Get seen, perfectly
    The webcam captures video in high definition, so people on the other side can see you and your wall charts clearly. This webcam also tilts 30°, adding to the screen's ability to tilt from -5° to 30° - so your team can relax, while the webcam moves to fit everyone in.
  • Four mics, two speakers
    You heard right. With four microphones and 2 speakers built into the front of this machine, your team's voices get picked up clearly, and you can hear the people on the other side, like they're there in the room with you.
  • Perfect for desks or walls
    This slender device fits onto the crowded desks and its stylish stand's ergonomic hinge lets you smoothly tilt it vertically between -5° and 30°. It's also designed to fit on a VESA mounting, so you can mount it on a wall or a wall-mounted rotating arm.
  • Superb touch control
    Capacitive 10-point multi-touch technology means your touchscreen follows every gentle stroke your fingers make, and you can use advanced gestures to control the computer easily and intuitively.
Acer Chromebase CA24I2 - all-in-one - Core i5 8250U 1.6 GHz - 8 GB - SSD 128 GB - LED 23.8"
Chromebox - all-in-one
Region: United Kingdom
1 x Intel Core i5 (8th Gen) 8250U / 1.6 GHz (, up to 3.4 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 128 GB
Optical Storage
No optical drive
Card Reader
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - touchscreen
Graphics Controller
Intel UHD Graphics 620
Camera
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
OS Provided
Google Chrome OS
54.06 cm x 4.18 cm x 43.68 cm
9 kg
Chromebox
Product Form Factor
All-in-one - with stand
Processor / Chipset
CPU
Clock Speed
1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Configuration Features
2 x 4 GB
Hard Drive
SSD
1 x 128 GB
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Monitor
Monitor Type
LED
Touchscreen
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Response Time
14 ms
Image Brightness
250 cd/m²
Monitor Features
Anti-glare
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Camera
Camera
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Audio Input
Microphone
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HDMI , 3 x USB 3.1 Gen 1 , 1 x USB 2.0 , 1 x audio line-out
2x wireless aerials
Power adapter
Power Provided
135 Watt
Operating System / Software
OS Provided
Google Chrome OS
54.06 cm
4.18 cm
43.68 cm
9 kg
