Acer C202i DLP WVGA 300 Lumens Projector
Quicklinx: F4TBWS00 Mfr#: MR.JR011.001
Superior Lighting
LED lighting lets you enjoy a wider colour gamut and greater durability than traditional lamps.
No More Waiting
The LED light source provides immediate on/off functionality, saving you valuable time and keeping you on the move.
Friend to the Environment
Acer EcoProjection reduces power consumption by up to 70% and can extend your lamp life up to 30,000 hours.
  • Amazingly portable
    Have fun anywhere, anytime or give presentations on the go with this compact, palm-sized projector.
  • Enhanced LED color gamut
    Enjoy a 1.2 - 1.4x wider NTSC color gamut and greater bulb durability than traditional lamps with LED lighting.
  • Wireless projection
    Break free from the clutter of wires with easy wireless projection options and wireless dongle design.
  • Integrated battery
    Enjoy full-length feature films without recharging with hours of renewable battery life. Use it as a power bank to charge your smart devices.
  • Integrated speakers
    What you hear will be just as good as what you see with the powerful built-in speakers.
  • Mobile USB display
    Share content quickly and conveniently via the USB cable.
  • Multimedia playback
    Easily share photos and documents from your personal USB drive with PC-free projection.
  • Instant On/Off
    Save valuable time when you're on the move thanks to the LED light source's immediate on/off functionality.
Acer C202i - DLP projector
DLP projector
Built-in Devices
Lithium-ion battery (9000 mAh)
Brightness
300 lumens
Contrast Ratio
5000:1
Resolution
WVGA (854 x 480)
Native Aspect Ratio
16:9
Colour Support
16.7 million colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
Video Input
- MPEG-1, MPEG-2, MPEG-4, XviD, H.264, VC-1
Speakers
Speaker(s) - internal
AC 120/230 V
30 watt
11.5 cm x 11.5 cm x 3.2 cm
350 g
DLP projector
Built-in Devices
Projector
Brightness
300 lumens
Contrast Ratio
5000:1
Image Size
73.66 cm - 254 cm
Projection Distance
0.7 m - 2.9 m
Throw Ratio
1.3:1
Resolution
WVGA (854 x 480) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
60 Hz x 33.2 kHz
Bulb type
LED
Bulb life cycle
4:3 aspect ratio support
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-20 / +20
Horizontal Keystone Correction
-20 / +20
Video Input
Video Interfaces
HDMI
Digital Video Format
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
2 watt
Speakers
1 x mixed channel
1 x USB - 4 pin USB Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x headphones
Carrying case, tripod, wireless remote control, power adapter
Power Source
AC / battery
AC 120/230 V
30 watt
11.5 cm
11.5 cm
3.2 cm
350 g
Limited warranty - 2 years , Limited warranty - lamp - 1 year
5 °C
80%
Sound Emission
29 dBA
25 dBA
