Acer's BE0 monitors offer a class-leading combination of ultra-high resolution screens, superb color definition, EyeProtect technologies, and a 4-side borderless zeroframe design so you can work comfortably all day.
- Acer BE270U - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 43 kWh
- Power Consumption (On mode)
- 30 W
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 75 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 6.25 kg
- Environmental Standards
- ENERGY STAR Qualified
- Directive 1275/2008, EN 50564:2011, EN55022:2010/AC:2011 Class B, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN 61000-3-3:2013, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Display Type
- Energy Class
- Class A
- 43 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- 6 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Black
- 6.25 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , DisplayPort , Audio line-out , 4 x USB 3.1 downstream , USB 3.1 upstream , USB-C
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB-C cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 30 W
- Power Consumption Stand by
- 490 mW
- 450 mW
Sustainability Information
- ENERGY STAR Certified
