Acer BE240Y 23.8" 1920x1080 6ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: CXFDWS00 Mfr#: UM.QB0EE.006
Acer’s BE0 monitors offer a class-leading combination of ultra-high resolution screens, superb colour definition, EyeProtect technologies and a 4-side borderless zeroframe design so you can work comfortably all day.
Acer BE240Y - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/376707
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
17 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
6.25 kg
Directive 1275/2008, EN 50564:2011, EN61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, IEC 62301:2011, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
6.25 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x MHL / HDMI , DisplayPort , Mini DisplayPort , DisplayPort output , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
180
Height Adjustment
150 mm
1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
17 W
17 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
490 mW
Power Consumption (Off Mode)
450 mW
