Acer B6 Series B226WL 22" 1680 x 1050 5ms VGA DVI LED Monitor
Quicklinx: 8NTJWS00 Mfr#: UM.EB6EE.005
Find the working angle that's perfect for you with a monitor that tilts, swivels, pivots and can be adjusted for height. The stand also has a magnetic area, perfect for holding paperclips and keeping your desk uncluttered. The monitor is also wall-mountable, giving you clear views with more room.
  • Gives you clear views with more room
    Find the working angle that's perfect for you with a monitor that tilts, swivels, pivots and can be adjusted for height. The stand also has a magnetic area, perfect for holding paperclips and keeping your desk uncluttered. These monitors are also wall-mountable, giving you clear views with more room.
  • Superior contrast ratios and ultra-quick response
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitors. Plentiful built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, and more realistic colors.
  • Faster and more productive
    Collaborating with others is faster and more productive when you have ample ports available. Professional series monitors allow you to connect to a wide variety of devices like notebooks and tablets.
  • RoHS compliant
    Professional series monitors are RoHS compliant and mercury free. In addition, the advanced Acer EcoDisplay design plus white LED backlighting yield significant power savings.
Acer B226WLymdr - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/367235
Energy Class
Class F
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Speakers
Internal
Display Position Adjustments
Height, pivot (rotation), tilt
Voltage
AC 120/230 V
Dark grey
50.58 cm x 22.12 cm x 33.41 cm
5.75 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TUV GS, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Zero Bright Dot, HDCP
Dark grey
5.75 kg
Audio
Speakers - stereo - internal
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
94
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
20 kWh/1000h
Power Consumption (Typical)
17.2 Watt
Power Consumption Stand by
0.45 Watt
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
