Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
- Acer B326HK - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class C
- Energy Consumption per Year
- 93 kWh
- Power Consumption (On mode)
- 64 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
- Height, swivel, tilt
- Dark grey
- 73.79 cm x 26.65 cm x 62.34 cm
- 12 kg
- Environmental Standards
- TCO Certified Displays 8
- Limited lifetime warranty
- Display Type
- Energy Class
- Class C
- 93 kWh
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Dark grey
- 73.79 cm x 26.65 cm x 62.34 cm - with stand
- 12 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- MHL / HDMI , DVI , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 60
- Cables Included
- 1 x DisplayPort cable , 1 x DVI cable , 1 x SuperSpeed USB cable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V
- 64 W
- 44 Watt
- Power Consumption Stand by
- 0.39 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 73.79 cm - depth: 6.2 cm - height: 45.36 cm - weight: 7.95 kg , With stand - width: 73.79 cm - depth: 26.65 cm - height: 62.34 cm - weight: 12 kg
- TCO Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £19.85 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £38.12 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
