Acer B3 Series B193L 19" 1280 x 1024 5ms VGA DVI LED Monitor
Quicklinx: 8NSWWS00 Mfr#: UM.CB3EE.A05
Explore the angle that's perfect for you with select Value Series monitors, which tilt to achieve the optimal position for extended viewing. Ergonomic designs provide handsome style on your desk - or off - these monitors are wall mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitors. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Adaptable
  • Convincing
  • Green focus
    Professional Series monitors are RoHS compliant and mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
Acer B193LAOymdr - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
Dark grey
40.8 cm x 20.6 cm x 36.2 cm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
GS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Pixel Per Inch
86
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Finnish, Russian, Spanish, Dutch
Acer EcoDisplay, eColor Management, 72% NTSC colour gamut
Dark grey
4.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
Mechanical
Tilt Angle
-5/+15
Swivel Angle
35
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hours
GS, ISO 9241-307
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
18.6 Watt
Power Consumption Stand by / Sleep
0.25 Watt
Included Software
Drivers & Utilities, Acer eDisplay Management
Dimensions & Weight Details
Without stand - depth: 6 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
