The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
Essential ergonomics
Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. -
Infused with color
In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision. -
A strong, ergonomic edge
Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice. -
Built-in speaker
The built-in speaker system lets you enjoy powerful sound without the need for a separate setup. -
A wide range of color
100% sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
 - Acer B287K bmiipprzx - LED monitor - 4K - 28" - HDR
 - LED-backlit LCD monitor - 28"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/404837
- Energy Class
 - Class F
- Energy Consumption per Year
 - 54 kWh
- Power Consumption (On mode)
 - 27 W
- Adaptive-Sync Technology
 - AMD Adaptive-Sync
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
 - 0.16 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1 / 100000000:1 (dynamic)
- HDR Capable
 - HDR10
- Response Time
 - 4 ms (grey-to-grey)
- Colour Support
 - 1.07 billion colours
- Colour Gamut
 - 90% DCI-P3
- Input Connectors
 - 2xHDMI, DisplayPort, Mini DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black
 - 63.7 cm x 20.8 cm x 52.4 cm
 - 7.5 kg
- Environmental Standards
 - TCO Certified Displays 8, ENERGY STAR Qualified
- Display Type
- Energy Class
 - Class F
- Energy Class (HDR)
 - Class G
 - 54 kWh
- Diagonal Size
 - 28"
 - AMD Adaptive-Sync
- Built-in Devices
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.16 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
- HDR Format
 - HDR10
- Colour Support
- Colour Gamut
 - 90% DCI-P3
- Response Time
- Vertical Refresh Rate
 - 40 - 60 Hz
- Horizontal Refresh Rate
 - 30 - 160 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Backlight Technology
 - LED backlight
 - Acer Adaptive Contrast Management (ACM), Adaptive-Sync technology, 3-sided bezeless, 8-bit + FRC Colour Depth
 - Black
 - 63.7 cm x 20.8 cm x 52.4 cm - with stand
 - 7.5 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - 2 x HDMI , DisplayPort , Mini DisplayPort , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
 - -5/+25
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 120 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
 - 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 27 W
- Power Consumption SDR (On mode)
 - 27 kWh/1000h
- Power Consumption HDR (On mode)
 - 46 kWh/1000h
- Power Consumption Stand by
 - 0.4 Watt
- Power Consumption Sleep
 - 0.45 Watt
 - 0.3 Watt
- Dimensions & Weight Details
 - With stand - width: 63.7 cm - depth: 20.8 cm - height: 52.4 cm - weight: 7.5 kg , Without stand - width: 63.7 cm - depth: 6.8 cm - height: 37.1 cm - weight: 5.28 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - 0 °C
 - 40 °C
 - 20 - 80%
