Acer B287Kbmiipprzx 28" 2840x2160 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: G9J3WS00 Mfr#: UM.PB7EE.004
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: Mini DisplayPort, DisplayPort, HDMI
£341.67 ex VAT
£410.00 inc VAT
The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
  • Essential ergonomics
    Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for.
  • Infused with color
    In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision.
  • A strong, ergonomic edge
    Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice.
  • Built-in speaker
    The built-in speaker system lets you enjoy powerful sound without the need for a separate setup.
  • A wide range of color
    100% sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
Acer B287K bmiipprzx - LED monitor - 4K - 28" - HDR
LED-backlit LCD monitor - 28"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/404837
Energy Class
Class F
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
27 W
Adaptive-Sync Technology
AMD Adaptive-Sync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
90% DCI-P3
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Voltage
63.7 cm x 20.8 cm x 52.4 cm
7.5 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
54 kWh
Diagonal Size
28"
AMD Adaptive-Sync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
HDR Format
HDR10
Colour Support
Colour Gamut
90% DCI-P3
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
40 - 60 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), Adaptive-Sync technology, 3-sided bezeless, 8-bit + FRC Colour Depth
63.7 cm x 20.8 cm x 52.4 cm - with stand
7.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort , Mini DisplayPort , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
180
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
27 W
27 kWh/1000h
Power Consumption HDR (On mode)
46 kWh/1000h
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 63.7 cm - depth: 20.8 cm - height: 52.4 cm - weight: 7.5 kg , Without stand - width: 63.7 cm - depth: 6.8 cm - height: 37.1 cm - weight: 5.28 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
20 - 80%
Diagonal Size: 28in
Response Time: 4ms
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Acer
