The Acer B286HK is optimized for maximum comfort. Boasting a multi-function ErgoStand with tilt, swivel, pivot and height adjustment, the display can tilt 25 degrees up or -5 degrees down for finding the best view. It can also swivel 60 degrees to the right or left, while the height can be adjusted 5.9 inches up or down. VESA compliant, it can be mounted on a wall to free up desk space. The Acer B286HK display comes with Acer ComfyView non-glare protection that provides a polarizer material to reduce unnecessary lighting reflection for clearer, more comfortable viewing. A crisp high maximum contrast ratio provides excellent clarity, while the fast response time contributes to sharp images, critical for video. The display boasts wide viewing angles up to 170 degrees horizontal and up to 160 degrees vertical. It has a 16:9 aspect ratio, 300 cd/m brightness. Offering excellent connectivity, the Acer B286HK comes with HDMI with MHL for charging smartphones, tablets and other portable devices. It also provides DVI, DisplayPort, Mini DisplayPort and a USB 3.0 hub, so users can connect multiple peripherals simultaneously.
Sharp details
Focus more clearly on your tasks thanks to the very high resolution of these monitors. The Ultra HD (4K2K) resolution delivers four times more pixels and detail than Full HD. -
Comfortable computing
Work comfortably for hours with Acer B6 Series monitors. These monitors deliver 100% sRGB coverage, for perfectly recreated colors. Acer ComfyView technology reduces glare, for greater eye comfort. -
Flexible design
Find a working angle that's perfect for you with the Acer ErgoStand, a stand that lets you easily adjust the screen's height, as well as letting you tilt and swivel it easily. Another great feature of the ErgoStand is that it allows you to effortlessly rotate the screen to portrait mode.
- Acer B286HKymjdpprz - LED monitor - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class C
- Energy Consumption per Year
- 66 kWh
- Power Consumption (On mode)
- 45 W
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Dark grey
- 65.87 cm x 24.72 cm x 40.85 cm
- Localisation
- EMEA
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 66 kWh
- Diagonal Size
- 28"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- ErgoStand, HDCP, Acer Adaptive Contrast Management (ACM), ComfyView
- Dark grey
- 65.87 cm x 24.72 cm x 40.85 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI , HDMI , DisplayPort , Mini DisplayPort , 4 x USB 3.0 , Audio line-in
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Localisation
- EMEA
- Input Voltage
- AC 120/230 V
- 45 W
- Power Consumption (Typical)
- 39 Watt
- Power Consumption Stand by
- 500 mW
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 65.87 cm - depth: 24.72 cm - height: 40.85 cm , Without stand - width: 65.87 cm - depth: 6.45 cm - height: 38.19 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
