Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision. The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
Essential ergonomics
Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. -
Infused with color
In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision. -
ZeroFrame design
The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. -
Built-in speaker
- Acer B277U bmiipprzx - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/427708
- Energy Class
- Class F
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 26 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.4 cm x 20.8 cm x 40.1 cm
- 7.77 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9 EPEAT Bronze
- DisplayPort 1.2
- Display Type
- Energy Class
- Class F
- 52 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 93
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- 4 ms
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 120 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Adaptive-Sync technology, Acer VisionCare, Acer BluelightShield technology, 6-Axis Color Adjustments, Acer ColorPlus technology, Acer Display Widget, 3-sided bezeless
- Black
- 61.4 cm x 20.8 cm x 40.1 cm - with stand
- 7.77 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- 2 x HDMI , DisplayPort 1.2 , Mini DisplayPort , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- DisplayPort 1.2
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- On / Off Switch
- Shipping Weight
- 10.81 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Bronze
