The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
ZeroFrame design
The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. -
Strong, ergonomic edge
Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice. -
Built-in speaker
The built-in speaker system lets you enjoy powerful sound without the need for a separate set up. -
Acer VisionCare
Acer VisionCare incorporates several technologies to reduce eye strain and includes Acer Flickerless, BlueLightShield, Low Dimming and Acer ComfyView. -
Wide range of color
100% sRGB means more color, more accurate, lifelike images for the professional who demands perfection. -
Designed for accuracy
Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colors and sharper overall visuals.
- Acer B277U - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 32.1 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 75 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 61.4 cm x 20.75 cm x 54 cm
- 8.22 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Display Type
- Energy Class
- Class G
- 52 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Zero Frame, 6-axis colour adjustment, Adaptive-Sync technology, Acer VisionCare, Acer ColorPlus technology
- 61.4 cm x 20.75 cm x 54 cm - with stand
- 8.22 kg
Audio
- Speakers - stereo
- DisplayPort , HDMI
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.41 Watt
- 0.28 Watt
- Dimensions & Weight Details
- With stand - width: 61.4 cm - depth: 20.75 cm - height: 54 cm - weight: 8.22 kg , Without stand - width: 61.4 cm - depth: 6.57 cm - height: 38.6 cm - weight: 5.98 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
