Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Flexible
Find the working angle that's perfect for you with a monitor that tilts, swivels, pivots and can be adjusted for height. The stand also has a magnetic area, perfect for holding paperclips and keeping your desk uncluttered. These monitors are also wall-mountable, giving you clear views with more room. -
Sharp
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitors. Plentiful built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, and more realistic colors. -
Connective
Collaborating with others is faster and more productive when you have ample ports available. Professional series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DVI, HDMI, USB 3.0 and DisplayPort. -
Ecological
Professional series monitors are RoHS compliant and mercury free. In addition, the advanced Acer EcoDisplay design plus white LED backlighting yield significant power savings. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
- Acer B276HUL - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/399171
- Energy Class
- Class G
- Energy Consumption per Year
- 66 kWh
- Power Consumption (On mode)
- 32.1 W
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, 2xDisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Dark grey
- 64 cm x 24.7 cm x 55.8 cm
- 8.51 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class G
- 66 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Mercury free, Acer eColor technology, 8-bit gamma
- Dark grey
- 64 cm x 24.7 cm x 55.8 cm - with stand
- 8.51 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- 2 x HDMI , DisplayPort , DisplayPort output , Audio line-in , 4 x USB 3.1 , USB-C
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Integrated cable management, portrait / landscape mode, VESA interface support, USB 3.0 port power off USB charging
- Cables Included
- 1 x DisplayPort cable , 1 x USB-C cable
- Input Voltage
- AC 120/230 V
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 32.8 Watt
- Power Consumption Stand by
- 490 mW
- Power Consumption Sleep
- 350 mW
- Dimensions & Weight Details
- With stand - width: 64 cm - depth: 24.7 cm - height: 55.8 cm - weight: 8.51 kg , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 6 kg
Sustainability Information
- ENERGY STAR Certified
