Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
Sharp details
Focus more clearly on your tasks thanks to the very high resolution of these monitors. Choose from WQHD resolution all the way up to Ultra HD (4K2K) resolution, which delivers four times more pixels and detail than Full HD. -
Comfortable computing
Work comfortably for hours with Acer B6 Series monitors. Acer ComfyView technology reduces glare, for greater eye comfort. In-Plane-Switching technology lets you see perfect images from wide viewing angles, for even more clarity and comfort. -
Brilliant colors
These monitors deliver 100% sRGB coverage, for perfectly recreated colors. Some models feature 6-axis color adjustment, which lets you fine-tune the colors for amazing color accuracy. -
Flexible design
Find a working angle that's perfect for you with the Acer ErgoStand, a stand that lets you easily adjust the screen's height, as well as letting you tilt and swivel it easily. Another great feature of the ErgoStand is that it allows you to effortlessly rotate the screen to portrait mode.
- Acer B276HK - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Energy Consumption per Year
- 75 kWh
- Power Consumption (On mode)
- 32.1 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms
- Input Connectors
- DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), tilt
- Dark grey
- 62.4 cm x 24.7 cm x 55 cm
- 7.82 kg
- Localisation
- United Kingdom, Europe, EMEA
- Microsoft Certification
- Compatible with Windows 7
- Display Type
- Energy Class
- Class G
- 75 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Response Time
- 6 ms
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Dark grey
- 62.4 cm x 24.7 cm x 55 cm - with stand
- 7.82 kg
Audio
- Speakers
- MHL / HDMI , DVI , Mini DisplayPort , USB 3.0 , DisplayPort
Mechanical
- Tilt Angle
- -5/+35
- Cables Included
- 1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Localisation
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 44.3 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 62.4 cm - depth: 24.7 cm - height: 55 cm - weight: 7.82 kg , Without stand - width: 62.4 cm - depth: 6.4 cm - height: 37 cm - weight: 5 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
