Acer B246WLAymdprx 24" 1920x1200 VGA DVI DP Monitor
Quicklinx: CPF6WS00 Mfr#: UM.FB6EE.A08
Acer provides a full scale of hardware and software products to meet the demands of today's business environment. Among the wide portfolio of Acer's business products, the B6 series are an extensive monitors range designed to cover any professional need. The stylish and simple ergonomic design enhances comfort over prolonged periods and increases productivity. Advanced panel technologies make every pixel colorful and vibrant, while compliance with eco-friendly standards helps save power and cut costs, reducing environmental impact.
  • Ergonomic design
    Combining professional style with ergonomic design and reflection-free Acer non-glare displays, the Acer B6 monitors perfectly suit all environments and viewing demands. Designed for professionals that spend a lot of time in front of a computer, Acer monitors can be adjusted to enhance the comfort over prolonged use. Moreover, Acer ComfyView feature reduces the reflection of ambient light to deliver vivid colors and less glare for the best viewing experience. The polarizer material diminishes unnecessary lighting reflection.
  • Outstanding color performance
    Acer ColorPlus is a set of technologies that ensures real and consistent color output in addition to sharper and clearer visuals. Built-in 100% sRGB color correction technology delivers the high color accuracy and color space reproduction desired by design professionals and photo enthusiasts for accurate color matching across applications and print output. A low Delta E value ensures accurate and consistent color, which substantially improves display quality, producing true color quality and uniform appearance across monitors. In addition, a 6-axis color independent adjustment permits precise color and saturation control for customized settings. The 178-degree wide viewing angle technology preserves image clarity and display colors without color shift or image distortion. In addition, extreme Black Monitor helps to deliver image details with deeper black levels, while the super sharpness technology optimizes lower resolution images for clearer image quality on a higher resolution monitor, for example, optimizing a 1080p photo for a 4K display.
  • Acer Adaptive Contrast Management
    The B6 series feature Acer Adaptive Contrast Management, a technology that fine-tunes each scene to make bright areas brighter and dark areas darker, optimizing contrast, for more detailed moving images. Acer Adaptive Contrast Management improves the input image directly, thereby realizing the full capability of the panel. Images look ultra-sharp and power is used efficiently.
  • White LED technology
    Acer B6 series integrate White LED technology that eliminates hazardous substances such as mercury or halogen gases and allows the reduction of power consumption by up to 68% compared to the traditional CCFL displays. What's more, LED lamps not only ensure exceptional reliability and great savings but also deliver better performance. In fact, they allow the reproduction of a larger color range with better saturation. The result is remarkable realism, unobtainable with standard technologies.
  • Acer Ergo-Stand
    Acer B6 monitor series comes with Acer Ergo-Stand, ensuring superior ergonomics and comfortable use. Featuring flexible height, tilt, pivot adjustment and a swivel foot-stand, B6 monitors easily adapt to any work style and blend into any office environment.
  • Height adjustment
    With height adjustment, users having different desks and heights can find the most suitable position for comfortable viewing. The stainless constant force spring stops at any height simply by pushing or lifting. You can adjust the height of B6 series up to 150mm.
  • Pivot
    The pivot design of the B6 series permits to rotate the display in portrait mode, which is useful for specific purposes such as scrolling through long web pages.
  • Tilt
    The tilt design ensures the best viewing angle for daily operation. You can adjust the viewing angle of B6 monitors from -5° to 35°.
  • Swivel
    With a swivel angle of 120°, B6 series monitors can be easily rotated on the stand, so that users can share the screen and let colleagues watch comfortably.
  • Maximum color accuracy
    Specifically designed for demanding users, Acer B6 High resolution monitors feature Acer ColorPlus, a set of technologies that ensures real and consistent color output in addition to sharper and clearer visuals. Built-in 100% sRGB color correction technology delivers the high color accuracy and color space reproduction desired by design professionals and photo enthusiasts for accurate color matching across applications and print output. A low Delta E value ensures accurate and consistent color, which substantially improves display quality, producing true color quality and uniform appearance across monitors. In addition, a 6-axis color independent adjustment permits precise color and saturation control for customized settings. The 178-degree wide viewing angle technology preserves image clarity and display colors without color shift or image distortion. In addition, extreme Black Monitor helps to deliver image details with deeper black levels, while the super sharpness technology optimizes lower resolution images for clearer image quality on a higher resolution monitor, for example, optimizing a 1080p photo for a 4K display.
  • Superior usability
    With Super Sharpness technology every detail comes into focus, making edges sharper and optimizing image quality. These monitors are also equipped with Low Dimming technology, that reduces the display brightness in dark environments to prevent eyestrain. In addition, large panels (up to 32"), resolutions up to 4K2K (four times Full HD) and cinematic 21:9 aspect ratio (B296CL model) make these monitors flexible to adapt to different usage scenarios.
  • Extensive connectivity
    Acer B6 High resolution monitors come with a rich stock of ports, including DVI, DisplayPort, MHL and USB 3.0 to seamlessly connect many types of devices. These monitors can be used to set up multiple displays configurations with daisy chain through video ports. The Picture in Picture feature allows better collaboration and productivity by joining two systems to a B6 monitor to share the same ultra-resolution working area.
Acer B246WL - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class G
Power Consumption (On mode)
28.3 W
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Dark grey
53.4 cm x 22.1 cm x 54.4 cm
6.3 kg
Environmental Standards
ENERGY STAR Qualified
RoHS
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, HDCP, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Acer eColor technology, 6-axis colour adjustment, 6-bit gamma, Wide Viewing Angle
Dark grey
53.4 cm x 22.1 cm x 54.4 cm - with stand
6.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI (HDCP) , DisplayPort , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
RoHS
Input Voltage
28.3 W
28.3 kWh/1000h
Power Consumption (Typical)
21 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
With stand - width: 53.4 cm - depth: 22.1 cm - height: 54.4 cm - weight: 6.3 kg , Without stand - width: 53.3 cm - depth: 5.33 cm - height: 35.6 cm - weight: 3.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
