Acer B246HYLAymidr 23.8" 1920x1080 6ms VGA DVI HDMI Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: CP9LWS00 Mfr#: UM.QB6EE.A01
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£158.36 ex VAT
£190.03 inc VAT
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
  • Full HD LED monitor
  • Acer Eco Display
    Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. Plus, as part of commitment to sustainable operations and CSR, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
  • ComfyView
    Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
  • ErgoStand
    The ergonomic design of this monitor optimizes the viewing position for maximum comfort even during prolonged use.
Acer B246HYL - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Height, pivot (rotation), tilt
Dark grey
55.44 cm x 22.12 cm x 37.91 cm
United Kingdom, Europe, EMEA
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class A
31 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), ComfyView
Dark grey
55.44 cm x 22.12 cm x 37.91 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA ¦ DVI ¦ HDMI
Mechanical
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
AC 120/230 V
23 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
Without stand - width: 55.44 cm - depth: 5.2 cm - height: 33.15 cm , With stand - width: 55.44 cm - depth: 22.12 cm - height: 37.91 cm
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Response Time: 6ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
