Acer B246HLymdr 24" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: G0GZWS00 Mfr#: UM.FB6EE.071
Ideal for use in office environments, libraries and computer labs, Professional series monitor delivers dynamic and energizing visuals. This monitor features eco-friendly technologies that save power and cut energy costs. It is also ergonomically designed, with a slim and clean-cut look.
  • Full HD
    1920x1080 resolution in a 16:9 aspect ratio makes movies more real and dramatic. Small details and text are clear.
  • Acm
    Whites are whiter, blacks are blacker and more detail is revealed in the shadows with Adaptive Contrast Management.
  • Acer eColor
    Easily adjust display settings to best suit whatever you're viewing - data, media, movies or photos.
  • Vesa mount
    Save space and add drama to a room by putting this display on a wall. VESA mounting makes it easy.
  • Acer EcoDisplay
    This display has an environmentally friendly design that focuses on recyclability, low power consumption, and more.
  • ErgoStand
    Tilt, swivel, and adjust the height of this display to get the perfect angle and enjoy the ultimate in comfort.
Acer B246HL ymdr - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Voltage
AC 120/230 V
Dark grey
56.7 cm x 22.12 cm x 53.55 cm
6.09 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TUV GS, ISO 9241-307
Display Type
Energy Class
Class F
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Zero Bright Dot, HDCP
Dark grey
56.7 cm x 22.12 cm x 53.55 cm - with stand
6.09 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI (HDCP)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
22.1 kWh/1000h
Power Consumption (Typical)
20.9 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 22.12 cm - height: 53.55 cm - weight: 6.09 kg , Without stand - width: 56.7 cm - depth: 5.2 cm - height: 53.55 cm - weight: 3.44 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
