Acer B246HLymdprz 24" 1920x1080 VGA DVI DP USB Monitor
Quicklinx: CPF9WS00 Mfr#: UM.FB6EE.013
Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
  • Full HD LED monitor
    The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
  • Acer Eco display
    Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. Plus, as part of its commitment to sustainable operations and CSR (corporate social responsibility), Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
  • ComfyView
    Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
  • ErgoStand
    The ergonomic design of this monitor optimizes the viewing position for maximum comfort even during prolonged use.
Acer B246HLymdprz - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/402263
Energy Class
Class F
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Height, pivot (rotation), tilt
Voltage
Dark grey
56.7 cm x 22.12 cm x 53.39 cm
United Kingdom, Europe, EMEA
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView
Dark grey
56.7 cm x 22.12 cm x 53.39 cm - with stand
Audio
Speakers - stereo - internal
Output Power / Channel
2 watt
DVI , VGA , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
22.1 kWh/1000h
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
