Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment. -
Acer Eco display
Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. Plus, as part of its commitment to sustainable operations and CSR (corporate social responsibility), Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact. -
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. -
ErgoStand
The ergonomic design of this monitor optimizes the viewing position for maximum comfort even during prolonged use.
- Acer B246HLymdprz - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/402263
- Energy Class
- Class F
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Dark grey
- 56.7 cm x 22.12 cm x 53.39 cm
- Localisation
- United Kingdom, Europe, EMEA
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView
- Dark grey
- 56.7 cm x 22.12 cm x 53.39 cm - with stand
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 2 watt
- DVI , VGA , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption SDR (On mode)
- 22.1 kWh/1000h
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- Dimensions & Weight Details
- Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
