Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for.
Essential Ergonomics
Planted upon its sturdy and robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. -
Infused with Colour
In the professional world, accuracy is everything. Utilise colour-enhancing and eye care technologies for pinpoint precision -
ZeroFrame Design
The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. -
A Strong, Ergonomic Edge
Courtesy of a firm, stainless steel base, you can easily tilt, pivot, swivel and make height adjustments at a moment's notice. -
Built-in Speaker
The built-in speaker system lets you enjoy powerful sound without the need for a separate set up. -
Resolution Matters
Choose from a wide range of resolutions from Full HD up to 4K UHD. -
A Wide Range of Colour
100% sRGB means more colour and more accurate, lifelike images for the professional who demands perfection. -
Designed for Accuracy
Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colours and sharper overall visuals. -
Casually Make Adjustments
No need to fiddle with the buttons. Easily modify your monitor settings via our convenient Acer Display Widget utility software.
- Acer B227Q - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/367183
- Energy Class
- Class F
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 19 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 49 cm x 19.3 cm x 37 cm
- 4.78 kg
- Localisation
- Poland
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 25 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 55 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Bluelight Filter, 72% NTSC colour gamut
- Black
- 49 cm x 19.3 cm x 37 cm - with stand
- 4.78 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- VGA , DisplayPort , HDMI , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable ¦ 1 x DisplayPort cable ¦ 1 x SuperSpeed USB cable
- MTBF
- 30,000 hour(s)
- Localisation
- Poland
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 13.5 watt
- Power Consumption Stand by
- 0.39 watt
- 0.27 watt
- Dimensions & Weight Details
- With stand - width: 49 cm - depth: 19.3 cm - height: 37 cm - weight: 4.78 kg , Without stand - width: 49 cm - depth: 6.5 cm - height: 29.5 cm - weight: 2.83 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
