Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
- Acer B226HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Power Consumption (On mode)
- 19 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Dark grey
- 50.8 cm x 22.1 cm x 36.9 cm
- 5.81 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- LED backlight
- ErgoStand, HDCP, Acer EcoDisplay, ComfyView, 72% NTSC colour gamut
- Dark grey
- 5.81 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA ¦ DVI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 60
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable ¦ 1 x DVI cable
- MTBF
- 30,000 hour(s)
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 16.5 Watt
- Power Consumption Sleep
- 0.45 Watt
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 22.1 cm - height: 36.9 cm - weight: 5.81 kg ¦ Without stand - width: 50.8 cm - height: 30.4 cm - weight: 3.17 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
