Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
- Acer B226HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 19 W
- Stereo speakers
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Dark grey
- 50.8 cm x 20.43 cm x 36.82 cm
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 27 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- Stereo speakers
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- ErgoStand, Acer EcoDisplay, ComfyView
- Dark grey
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 60
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 19.5 Watt
- Power Consumption Sleep
- 0.35 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 20.43 cm - height: 36.82 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
