The Aspire R 13 boasts intelligent construction and smart features that enhance work and play. Thanks to the futuristic Ezel Aero Hinge, you can transition effortlessly between six different user modes. Masterfully crafted with premium features such as Corning Gorilla Glass 3, a WQHD screen and the Acer Active Pen, the Aspire R 13 is a laptop that might just change.
Smart hinge, great flexibility
Acer's innovative Ezel Aero Hinge features two separate hinge mechanisms that work together to allow seamless transition between six user modes. This fantastic hinge also keeps the display very stable when you use it for touch control. -
Thin, light, and tough
The touchscreen and its back cover are encased in two slices of Corning Gorilla Glass 3 - which makes the top panel very tough, beautiful, and strikingly slender. At only 1 inch thin (17.95 mm) thin, the Aspire R 13 is a joy to pack and carry. -
A pen for your thoughts
The Aspire R 13's touchscreen works perfectly with the Acer Active Pen, which uses Acer Hover Access technology to activate pop-up, tap-on menus. The result is a more intuitive writing experience that is also very convenient, fun and productive. -
Visual delight
You can choose between a WQHD display with power-saving IGZO technology that delivers super-crisp images, or a full HD display with wide viewing angles (IPS technology) and optical clarity solutions. All models feature direct bonding (zero air gap) for a brighter, crisper display. -
Cinematic surround sound
Immerse yourself in movies with dolby digital plus home theater - sound technology that is crafted to bring every movie to life and put you in the middle of the action. -
Comfortable viewing
Corning's AR/ETC (antireflective and easy-to-clean) glass coating reduces screen glare and improves contrast, while also making it very easy to clean the screen. A built-in light sensor auto-adjusts brightness levels to further enhance eye comfort and power efficiency. -
Great video conferencing
This laptop has dual-array microphones for noise-free voice communication. Acer Purified. Voice technology tracks the voice of the speaker as he or she moves around the room. The Aspire R 13 is also skype certified because it has all the high-quality hardware required for great audio and video chats.
- Acer Aspire Pro Series R7-372T - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook - flip-hinge design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3
- Storage
- 128 GB SSD
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac
- Battery
- 4-cell
- Grey
- 34.38 cm x 23.035 cm x 1.85 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 128 GB SSD M.2
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare, Corning Gorilla glass 3
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
- Dolby Digital Plus Home Theater
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 4-cell
- Capacity
- 3315 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 2.0 , 2 x USB 3.0 , HDMI , Headphone/microphone combo jack , USB-C (supports Thunderbolt 3)
- Grey
- Security lock slot (cable lock sold separately), volume control, Acer Purified.Voice technology, MU-MIMO technology
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 1.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
