Acer Aspire XC-705 Core i5-4460 8GB 1TB Windows 10
Quicklinx: CJ41WS00 Mfr#: DT.SXMEK.047
  • Core i5
  • IEEE 802.11n
Maximize your creativity and your desk space, too. Small enough to fit anywhere, the compactly styled Aspire X Series is just one-third the size of a tower PC, yet it offers plenty of power and performance for your multimedia creativity and HD entertainment.
  • Fit in well
    Easy to place, easy to set up: whether on a bookcase shelf, in a corner of your desk, or tucked underneath, this compact PC just fits. It's perfect for storing movies and media, as a gaming or learning machine in the kids' room, or as a homework tool for students in cramped dorms.
  • Full power
    Finish tasks, watch programming, play casual games, and keep in touch with friends - all easy with high-capacity processing. Press the blue LED power button and command your world.
  • HD fun
    Wonderfully compact and wonderfully entertaining: the Aspire X Series is your high-definition multimedia center. Plus, you can easily take the multimedia experience to your big screen, thanks to the HDMI port integrated on every Aspire X Series desktop.
  • Expandable
    Transfer media easily from your digital devices using the front card reader or swift USB 3.0 ports.
Acer Aspire XC-705_H_WLP - SFF Core i5 4460 3.2 GHz - 8 GB - HDD 1 TB
Personal computer - SFF
Region: United Kingdom
Intel Core i5 (4th Gen) 4460 / 3.2 GHz (up to 3.4 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB L3 Cache
Cache Per Processor
6 MB
RAM
8 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
Intel HD Graphics 4600
Audio Output
5.1 channel surround
1GbE, Bluetooth, 802.11b/g/n
AC 230V
OS Provided
Windows 10 Home 64-bit Edition
36.7 cm x 26.95 cm x 10 cm
9 kg
Personal computer
Product Form Factor
SFF
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
L3 Cache - 6 MB
Cache Per Processor
6 MB
RAM
Installed Size
DDR3L SDRAM
Effective Memory Speed
1600 MHz
DIMM 240-pin
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Bays
5.25" , 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x Mini PCIe , 1 PCIe x1 , 1 PCIe x16
2 x USB 2.0 (2 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x LAN (Gigabit Ethernet) , 3 x USB 3.0 (2 front, 1 rear) , 1 x audio line-in
Wireless antenna
BSMI, CB, CCC, RoHS, EuP
Power supply
AC 230V
Power Provided
220 watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
36.7 cm
26.95 cm
10 cm
9 kg
