Acer Aspire Switch SW5-012 Intel Atom Quad Core Z3735F 2GB 64GB 10.1" Windows 8.1 32-bit
Quicklinx: 9T0JWS00 Mfr#: NT.L6JEK.011
  • Atom
  • Windows 8.1 with Bing 32-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Whether you're an indoors person, an outdoors person, or a bit of both, the Aspire Switch 10 is designed to be used every day, everywhere you go. With the resolution to bring details to life and the resilience to battle wear and tear, the Aspire Switch 10 is a stunning device you will want to share.
  • A spectacular view
    With the resolution to bring details to life and the resilience to battle wear and tear, the Aspire Switch 10 is a stunning device you will want to share. WUXGA display, Zero Air Gap, and IPS technology combine to provide vivid clarity and bright color from every angle.
  • Super-strength glass
    The Gorilla Glass 3 makes your display tougher than ever with Native Damage Resistance. Gorilla Glass 3 provides better scratch resistance and reduces existing scratch visibility.
  • A mode for every instant
    The Aspire Switch 10 transforms into four distinct modes that enable you to multitask in any environment. Detach and use it as a tablet, get tasks done in laptop mode, pivot its screen to share, or flip to watch a movie when space is limited.
  • Acer Snap Hinge
    Flip, rotate, or detach in a snap - the Aspire Switch 10's unique Acer Snap Hinge uses the invisible force of magnetism to provide a latch-less docking solution that lets you smoothly remove and re-attach the keyboard to the display.
  • Brushed aluminum design
    Acer's innovative nano-imprint technology offers a wide range of stylish laptop cover options using new environmentally friendly manufacturing processes. The rear cover of the Aspire Switch 10 is made from aluminum and NIL technology and is finished with a gentle gray brush stroke, creating an elegant and unique design.
  • Super thin and feather light
    At a mere 8.9 mm thin in tablet mode, the Aspire Switch 10 transforms into slim 2-in-1 laptop. You can effortlessly keep the Aspire Switch 10 at your side all day long.
  • Zero Air Gap
    Zero Air Gap technology unites touch and sight better than ever for a truly impressive touchscreen experience. This technology directly bonds the module to the touch panel thereby eliminating reflections, which can degrade contrast and viewing angles, especially in sunlight conditions.
  • Acer LumiFlex display
    Whether you're an indoors person, an outdoors person, or a bit of both, the Aspire Switch 10 is designed to be used every day, everywhere you go. Its Acer LumiFlex display technology provides optimized color control that lets you watch videos and share photos even under the sun.
Acer Aspire Switch 10 SW5-012-19W6 - 10.1" - Intel Atom - Z3735F - 2 GB RAM - 64 GB eMMC
Tablet - with keyboard dock
Operating System
Win 8.1 with Bing 32-bit
Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
2 GB DDR3L (provided memory is soldered)
Storage
64 GB eMMC
Display
10.1" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics
Input Device
Touchpad, detachable keyboard
Integrated Webcam
802.11b/g/n, Bluetooth 4.0
2-cell
Ambient light sensor, G-sensor
Dockable
Grey, silver
1.17 kg
Region: United Kingdom
Operating System
Processor / Chipset
CPU
Max Turbo Speed
1.83 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
2 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
64 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Glare, CineCrystal, Corning Gorilla glass 3, Zero Air Gap technology
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1920 x 1080
Resolution
2 Megapixel
Camera Features
1080p Full HD movie recording
Sound
Stereo speakers, microphone
Input
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
2-cell lithium polymer
5700 mAh
AC Adapter
Input
Output
18 Watt, 12 V, 1.5 A
Connections & Expansion
Micro-USB 2.0 , Micro-HDMI , Headphone output , Dock , USB 2.0 (on keyboard dock)
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft 365 (1 year subscription)
Grey, silver
Integrated Options
Dockable
Digital compass, gyroscope, Acer Snap Hinge
Power adapter
Localization
1.17 kg
Dimensions (WxDxH) / Weight Details
26.16 cm x 17.71 cm x 0.89 cm / 585 g - tablet
9T0J C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
9T0J C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
