Pick up the Aspire R, and you'll see the world. Because with a powerful computer fluidly moving between four modes, there are no limits to the work that can be created, moments shared, games played, connections made. Discover a computer that's everything you need it to be.
360-degree dual-torque hinge
The 360-degree dual-torque hinge offers easy one-handed conversion and a wobble-free touch experience. The laptop also lays 180 degrees flat for collaboration and sharing. -
Zero Air Gap
Zero Air Gap technology unites touch and sight better than ever for a truly impressive touchscreen experience. This technology directly bonds the touch panel to the LCD, significantly reducing reflection while improving contrast and image clarity, especially in bright light. -
Matches your moves
When you flip the Aspire R display to switch modes, the audio channels and video display automatically reverse to the correct orientation. You can also set default wallpapers for each mode.
- Acer Aspire R 11 R3-131T-P02Q - 11.6" - Intel Pentium - N3700 - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Pentium N3700 / 1.6 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, 10/100 Ethernet
- Battery
- 4-cell
- G-sensor
- Black, blue
- 29.8 cm x 21.1 cm x 2.09 cm
- 1.58 kg
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Ultra Slim Design, HDCP, frameless, glare, CineCrystal, Mercury free
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - M.2 Card
- Network Interface
- 10/100 Ethernet
- Technology
- 4-cell lithium polymer
- Capacity
- 3270 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- USB 2.0 , Headphone output , HDMI , LAN , USB 3.0
- Memory Card Reader
- Yes (SD Card)
- Black, blue
- Integrated Options
- G-sensor
- MIMO technology
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 1.58 kg
