Acer Aspire Pro S7-393 Intel Core i5-5200U 8GB 256GB SSD 13.3" Windows 8.1 Professional
Quicklinx: BKFYWS00 Mfr#: NX.MT5EK.003
  • Core i5
  • Windows 8.1 Pro 64-bit Edition
  • IEEE 802.11n
The aluminum unibody plus Gorilla Glass 2 design of the Aspire S7 makes it incredibly slender, light and strong. At less than 12.9 mm, it's the thinnest Ultrabook with a super-crisp Full HD touch display on the market. And, the dual-torque hinge keeps the display very stable when you use it for touch control.
The Aspire S7's Full HD display generates deep detail and puts 10-point touch control at your fingertips. This Ultrabook is made for teamwork: Open it to 180 degrees, punch a hotkey to flip the view, and you're in shape to share. Take the show to a big screen, wire-free, via newly featured WiDi connectivity.
  • Premium build
  • Touch and show
  • Quick and clear
    You can work and play faster than ever on the Aspire S7, as it packs a RAID 0 solid state drive (SSD) with two times faster performance than standard SSDs. Another fresh feature is Acer Purified.
Acer Aspire Pro Series S7-393 - 13.3" - Intel Core i5 - 5200U - 8 GB RAM - 256 GB SSD
Ultrabook
Operating System
Win 8.1 Pro 64-bit
Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
8 GB DDR3L (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" LED backlight touchscreen 2560 x 1440 / WQHD
Graphics
Intel HD Graphics 5500
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 11.5 hours
Ambient light sensor
White, silver
32.3 cm x 22.3 cm x 1.29 cm
1.3 kg
Region: United Kingdom
Ultrabook
Operating System
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U / 2.2 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
256 GB SSD SATA 6Gb/s
RAID Level
RAID 0
Display
13.3"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2560 x 1440 (WQHD)
Widescreen
Image Aspect Ratio
16:9
HDCP, Corning Gorilla glass, anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording
Sound
Stereo speakers, two microphones
High Definition Audio, Dolby Digital Plus Home Theater
Input
Keyboard, touchpad
Keyboard Backlight
Acer ZoomPerfect touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Acer SignalUp
4-cell lithium polymer
47 Wh
Run Time
Up to 11.5 hours
Battery Run Time
Video playback: up to 8.5 hours , Web browsing: up to 10 hours
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
2 x USB 3.0 , HDMI , Acer converter port , Headphone output
Memory Card Reader
2 in 1 (SD Card)
White, silver
Integrated Options
MIMO technology, USB 3.0 port power off USB charging, Acer Purified.Voice technology
Cleaning cloth, power adapter, carrying case
Localization
1.3 kg
