The advanced Aspire E5-574-56NR laptop features an attractive design that exceeds expectations. With many enhanced components, and a textured surface, the E5-574-56NR is a good bit better at delivering a good bit more.
- Acer Aspire E 15 E5-574-56NR - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell
- Grey, black
- 38.16 cm x 25.6 cm x 2.92 cm
- 2.4 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 2520 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- HDMI , VGA , LAN , 2 x USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- Grey, black
- Wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
