The Aspire E 11 stands out in a crowd because of its unique and cool FlowCurve design. The large precision touchpad is optimized for accuracy and sensitivity, giving you a touch-gesture experience that's as smooth as on a touchscreen. This laptop is thin and light, so you can tuck it in your bag and forget about it. This wonderful portability combines with impressive processing and huge storage for great productivity wherever you roam.
Perfect for work and play
The Aspire E 11 comes with a full-sized keyboard, all the right ports, and the full suite of productivity programs, so you can get a lot done wherever you go. Plus, the optimized speakers deliver audio similar to what you'd expect from larger notebooks, for surprisingly clear sound. -
Cool and whisper-quiet
This notebook doesn't just look cool on the outside. It is designed to not require a cooling fan, so it runs cool and whisper-quiet, for a very comfortable user experience. No fan vents to blow hot air on you, no whining fan noise when you're watching your favorite movies. It's cool, by design. -
Fast browsing and downloads
The Ethernet port isn't just any old Internet jack. This jack supports Gigabit LAN, which means you can surf the web and send files at up to 1000 megabits per second, which means you can enjoy very smooth web browsing and very fast downloads and uploads.
- Acer Aspire E3-112-C6SV - 11.6" - Intel Celeron - N2840 - 2 GB RAM - 320 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 with Bing 64-bit
- Processor
- Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache
- Memory
- 2 GB DDR3L (1 x 2 GB)
- Storage
- 320 GB HDD / 5400 rpm
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell
- Silver
- 29.1 cm x 21.1 cm x 2.12 cm
- 1.39 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 8.1 with Bing 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.58 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (1 x 2 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HDCP, anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording, Acer Crystal Eye HD
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell lithium polymer
- Capacity
- 2670 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 40 Watt, 19 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , USB 3.0 , USB 2.0 , LAN
- Memory Card Reader
- Yes (SD Card)
- Silver
- Wake on LAN
- Included Accessories
- Power adapter
- Localization
- 1.39 kg
