The Acer Chromebook 15 C910 is the world's first Chromebook with a 15.6" Full HD wide viewing angle display, meaning you can do much more on a Chromebook than ever before. The bigger screen also means a bigger body, freeing up room for two big upward-facing speakers that make the Full HD1 viewing experience sound high-definition as well. In addition, the Acer Chromebook 15 C910 also features an incredibly fast processor. Powered by the latest Intel processor based on Broadwell micro-architecture, the Acer Chromebook 15 C910 blows away anything you've seen before. Additionally, the ultra-fast MIMO 2x2 802.11ac wireless connection helps boost internet speeds to up to three times faster than previous generations The Acer Chromebook 15 C910 is big and fast enough for all-day use, so it's also been designed to feel great. The fabric-textured surface is comfortable, the non-glare Acer ComfyView display doesn't strain your eyes, and the touchpad - the largest of any Chromebook - provides plenty of room to scroll and gesture freely.«
The right size
The Acer Chromebook 15 C910 is the world's first Chromebook with a 15.6" Full HD wide viewing angle display, meaning you can do much more on a Chromebook than ever before. The bigger screen also means a bigger body, freeing up room for two big upward-facing speakers that make the Full HD1 viewing experience sound high-definition as well. -
The right speed
In addition, the Acer Chromebook 15 C910 also features an incredibly fast processor. Powered by the latest Intel processor based on Broadwell micro-architecture, the Acer Chromebook 15 C910 blows away anything you've seen before. Additionally, the ultra-fast MIMO 2x2 802.11ac wireless connection helps boost internet speeds to up to three times faster than previous generations -
The right feel
- Acer Chromebook C910-C3ZK - 15.6" - Intel Celeron - 3205U - 4 GB RAM - 32 GB SSD - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Celeron 3205U / 1.5 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB SSD
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 4-cell
- Black
- 38.3 cm x 25.6 cm x 2.42 cm
- 2.2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB SSD
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Technology
- 4-cell
- Capacity
- 3270 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V
Connections & Expansion
- Interfaces Details
- HDMI , USB 2.0 , USB 3.0 , Headphone/microphone combo jack
- Memory Card Reader
- 2 in 1 (SD Card)
- Black
- MIMO technology
- Included Accessories
- Power adapter
- Localization
- 2.2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
