The Acer C7 Chromebook starts in seconds and runs your favorite apps. Thin and light, this Chromebook goes wherever you go and keeps your files safe and secure.
Advanced performance
Start in seconds and have this laptop feeling every time. No updates to track, no discs to insert, and backups are automatic, too. Plus, its intuitive interface makes it all so simple. -
HD experience
The Acer C7 Chromebook's HD screen energizes your videos, pictures and web content. Crisp resolution brings family closer during video chats. Images are crystal clear on HD devices like monitors, projectors and TVs via the HDMI port, and connect as you please with a few USB ports plus VGA. -
Simple start
This Chromebook requires almost no setup, so you can go from unboxing to doing in minutes. Tasks are easy using the large, button-free touchpad. Stay online with the Acer C7 Chromebook's convenient and reliable wireless connection.
- Acer Chromebook R 11 C738T-C439 - 11.6" - Celeron N3050 - 4 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N3050 / 1.6 GHz (2.16 GHz) / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Black
- 29.4 cm x 20.4 cm x 1.92 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Technology
- 3-cell
- Capacity
- 3490 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- Black
- Case Material
- Aluminum
- Included Accessories
- Power adapter
- Localization
- 1.6 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
